How do I add a field to an Epicor Tracker
That's over my head. I think I will try to create a new dashboard to
replace Epicors.
Mike
b_ordway
Sent: Wednesday, October 10, 2012 11:52 AM
Subject: [Vantage] Re: How do I add a field to an Epicor Tracker
I don't know that there is any way to add fields that I'd call easy.
Here is a previous post that gives a basic example of adding a field:
http://tech.groups.yahoo.com/group/vantage/message/107748
I believe there are also some examples on this board for using the
dyanamicquery adapter.
One caution.
If your grid is handling more than a few rows, these types of customizations
can really slow down form. I'm guessing PartTran might be one of those that
would really suffer.
"mike.numbers" <mnumbers@...> wrote:
> I want to add the DMR number to the Part Transaction History tracker. I
already checked to make sure this field was not hidden in the current
program. What is the easiest way to add this field. PartTran contains the
field and this is the source for most if not all of the fields on the
tracker.
I want to add the DMR number to the Part Transaction History tracker. I already checked to make sure this field was not hidden in the current program. What is the easiest way to add this field. PartTran contains the field and this is the source for most if not all of the fields on the tracker.
I believe there are also some examples on this board for using the dyanamicquery adapter.
One caution.
If your grid is handling more than a few rows, these types of customizations can really slow down form. I'm guessing PartTran might be one of those that would really suffer.
