I have been off for a week and am trying to get this to work. I am getting
the error message - "too many characters in character literal" on the
DataSet ds statement. I believe my single and double quotes are correct.
The problem has to be in the where clause section, but I don't know C+ well
enough to either shorten the phrase or correct it.
Any help would be appreciated.
// Custom C# code for PartTranHistForm
// Created: 10/17/2012 10:11:20 AM
using System;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using System.ComponentModel;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Searches;
using Epicor.Mfg.BO;
using Epicor.Mfg.Core;
using Epicor.Mfg.Lib;
public static class Script
// ** Wizard Insert Location - Do Not Remove 'Begin/End
Wizard Added Module Level Variables' Comments! **
static Epicor.Mfg.UI.FrameWork.EpiUltraGrid myGrid;
static BOReader _boReader;
public static void InitializeCustomCode()
// ** Wizard Insert Location - Do not delete
'Begin/End Wizard Added Variable Initialization' lines **
// Begin Wizard Added Variable
Initialization
myGrid=(Epicor.Mfg.UI.FrameWork.EpiUltraGrid)csm.GetNativeControlReference("
f83d6262-a7d9-4fb5-a7d0-54644a9bb66b");
myGrid.DisplayLayout.Bands[0].Columns.Add("DMRNum","DMR Number");
myGrid.InitializeRow += new
Infragistics.Win.UltraWinGrid.InitializeRowEventHandler(grdMatLst_Initialize
Row);
_boReader = new
BOReader(((Session)oTrans.Session).ConnectionPool);
private static void grdMatLst_InitializeRow(object sender,
Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e)
DataSet ds =
_boReader.GetRows("PartTran","Company="'FormName.Session.CompanyID+'" AND
TranNum="'e.Row.Cells["TranNum"].Value.ToString()+'"","DMRNum");
public static void DestroyCustomCode()
'Begin/End Wizard Added Object Disposal' lines **
// Begin Custom Code Disposal
// End Custom Code Disposal
myGrid.InitializeRow -= new
Row);
_boReader=null;
----------errors------------
Error: CS1012 - line 55 (151) - Too many characters in character literal
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Ted Koch
Sent: Wednesday, October 17, 2012 4:40 PM
To:
Subject: Re: [Vantage] How do I add a custom program to the "Open With"
menus
Try this...
DataSet ds =
_boReader.GetRows("PartTran","Company = '" +
FormName.Session.CompanyID + "' AND TranNum='" +
e.Row.Cells["TranNum"].Value.ToString()+"'","DMRNum");
mnumbers@... <mailto:mnumbers%40cignys.com> >
To:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Sent: Wednesday, October 17, 2012 3:29 PM
Subject: RE: [Vantage] How do I add a custom program to the "Open With"
menus
I am no longer getting errors. I need some help with the DataSet
statement. If I understand correctly the format is:
DataSet ds = _boReader.GetRows("business object","where clause","returned
field");
How do I find the business object for PartTran?
I don't understand the format on the example you have in the Chart Tracker
example for the Where clause. Somehow we need to use the company/trannum
for the row.
The returned field should be "DMRNum".
Hopefully this will be the final question.
Thanks again.
Mike
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Jose Gomez
Sent: Wednesday, October 17, 2012 2:46 PM
To:
menus
You need to maky any and all declarations and functions static as such, do
that for EVERY function.
private static void grdMstLst_InitializeRow(object sender,
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E:
jose@... <mailto:jose%40josecgomez.com>
http://www.josecgomez.com
http://www.linkedin.com/in/josecgomez> <
http://www.facebook.com/josegomez>
http://www.google.com/profiles/jose.gomez> <
http://www.twitter.com/joc85>
http://www.josecgomez.com/professional-resume/>
http://www.josecgomez.com/feed/>
http://www.usdoingstuff.com>
On Wed, Oct 17, 2012 at 2:42 PM, Mike Numbers <
mnumbers@...
<mailto:mnumbers%40cignys.com> > wrote:
> I had to add Epicor.Mfg.Lib.IBOReader.dll and
> Epicor.Mfg.Core.BLConnectionPool.dll.
> I uncommented the other statements and am now receiving the following
> message.
> Compiling Custom Code ...
> Error: CS0708 - line 53 (149) - 'grdMstLst_InitializeRow': cannot
> declare
> instance members in a static class
> ** Compile Failed. **
> Line 53 = private void grdMstLst_InitializeRow(object sender,
> I tried putting static in front of grdMstLst but received another
> error so I took it back out.
> See code below:
> // Custom C# code for PartTranHistForm // Created: 10/17/2012 10:11:20
> AM
> using System;
> using System.Data;
> // ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added
> Module Level Variables' Comments! ** // Begin Wizard Added Module
> Level Variables **
> // End Wizard Added Module Level Variables **
> // Add Custom Module Level Variables Here ** static
> Epicor.Mfg.UI.FrameWork.EpiUltraGrid myGrid; static BOReader
> _boReader;
> public static void InitializeCustomCode() {
> // ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added
> Variable Initialization' lines ** // Begin Wizard Added Variable
> Initialization
> // End Wizard Added Variable Initialization // Begin Wizard Added
> Custom Method Calls
> // End Wizard Added Custom Method Calls
> Number");
> ialize
> Row);
> _boReader = new
> Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e) {
> public static void DestroyCustomCode() {
> Object Disposal' lines ** // Begin Wizard Added Object Disposal
> // End Wizard Added Object Disposal
> //myGrid.InitializeRow -= new
> ialize
> Row);
[mailto:
> Behalf Of John Driggers
> Sent: Wednesday, October 17, 2012 2:10 PM
> menus
> Set your BO reader as static as we did with the grid. That should sort
> that out.
> I noticed that you commented out the sections where you were wiring up
> the eventhandler on the grid. Assuming this fixes your BOReader issue,
> let's uncomment those next and see what we get.
> *John Driggers*
> *Chief Data Wrangler*
> *I have an Epicor blog <http://usdoingstuff.com/>. How useful is
> that?*
> *:: 904.404.9233
> :: waffqle@... <mailto:waffqle%40usdoingstuff.com>
> :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> On Wed, Oct 17, 2012 at 1:35 PM, Mike Numbers <mnumbers@...
> > Thanks again for your help.
> > Below is my code. I have commented out statements that were giving
> > me errors. I eventually stopped following your example and sent you
> > my previous email. I uncommented the BOReader statements and tested my
code.
> > The error is at the bottom.
> > 10:11:20 AM
> > using System;
> > using System.Data;
> > Level Variables **
> > Epicor.Mfg.UI.FrameWork.EpiUltraGrid myGrid; BOReader _boReader;
> > Initialization
> > Custom Method Calls
> > Number");
> > //myGrid.InitializeRow += new
> > it
> > ialize
> > Row);
> > _boReader = new
> > //private void grdMstLst_InitializeRow(object sender,
> > Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e) //{
> > it
> > ialize
> > Row);
> > Error: CS0708 - line 34 (128) - 'Script._boReader': cannot declare
> > instance
> > FYI
> > Line 34 = BOReader _boReader;
[mailto:
> > Sent: Wednesday, October 17, 2012 1:14 PM
> > menus
> > We're always happy to help!
> > Without looking deeper into it, I'm not sure why the grid is
> > different in our code. That form could work a bit differently, or
> > maybe it's just an error in the code we posted.
> > The main purpose of the code in our example is to pull values from
> > other tables. Generally the Epicor dataviews contain all the fields
> > from a given table, but if that isn't the case for this scenario,
> > the code should still do the job.
> > Regarding the BOReader, the first parameter is the BusinessObject
> > you want to use, not the table. BOReader basically calls the 'GetRows'
> > method on that BusinessObject with the WhereClause you provide and
> > only returns the fields you specify. Its main purpose is to allow
> > you to do quick queries against various BusinessObjects without the
> > hassle of instantiating/disposing a BO and pulling in references,
> > etc. It also saves you the performance hit inherent in returning a
> > potentially large dataset when you only need a column or two.
> > As for your other errors, it's probably best to handle them one at a
> time.
> > If you'd like, post the errors you get when testing the code and the
> > offending code and we'll just go through em one by one.
> > *John Driggers*
> > that?*
> > *:: 904.404.9233
> > On Wed, Oct 17, 2012 at 12:35 PM, Mike Numbers <mnumbers@...
> > wrote:
> > > John,
> > > I was pointed to your blog and your example of adding a column to
> > > an Epicor tracker. My programming background is not in C# or VB
> > > but the logic normally makes sense and I am learning by example.
> > > The example you have on your blog looks like it is pulling in
> > > another table for the
> > information.
> > > The field I need is actually on the parttran table, it just is not
> > > listed in the Collection for the dashboard. I am getting some
> > > errors that I don't understand and was wondering if you could
> > > explain them to me or point me in the right direction. First was
> > > the error I got about the grid being a "static" grid. Why is this
> > > grid different from the one in your blog? After I changed the grid
> > > to static, I got errors on the BOReader statements and the
> > > grdMatLst statements. I assume these are all related. Also the on
> > > the DataSet ds statement with GetRows I
> > thought the first parameter "APInvoice"
> > > would be the table to read, "InvoiceNum=... would be the key, and
> > > "InvoiceDate" would be the field getting pulled. But the APInvoice
> > > table does not exist, APInvHed does.
> > > I appreciate all of the help you guys have given me and I realize
> > > this isn't your job. With that said, any additional help or
> > > pointers would be appreciated.
> > > Thanks
> > > Mike
[mailto:
> > > Sent: Wednesday, October 17, 2012 10:49 AM
With"
> > > menus
> > > Just change:
> > > To:
> > > *John Driggers*
> > > that?*
> > > *:: 904.404.9233
> > > On Wed, Oct 17, 2012 at 10:39 AM, Mike Numbers
> > > <mnumbers@... <mailto:mnumbers%40cignys.com> >
> > > wrote:
> > > > I don't understand that. How do I do it?
> > > > Mike
[mailto:
> > > > On Behalf Of John Driggers
> > > > Sent: Wednesday, October 17, 2012 10:34 AM
> > > > "Open
> With"
> > > > menus
> > > > Your grid needs to be static.
> > > > *John Driggers*
> > > > that?*
> > > > *:: 904.404.9233
> > > > On Wed, Oct 17, 2012 at 10:27 AM, Mike Numbers
> > > > wrote:
> > > > > I am getting a compile error after adding the first 2 lines of
> code.
> > > > > using System;
> > > > > using System.Data;
> > > > > // Begin Wizard Added Module Level Variables **
> > > > > // Begin Wizard Added Variable Initialization
> > > > > // Begin Wizard Added Custom Method Calls
> > > > > Error: CS0708 - line 31 (123) - 'Script.myGrid': cannot
> > > > > declare instance members in a static class
> > > > > Any ideas on what I did wrong here? I copied from the Part
> > > > > Transaction History Tracker.
[mailto:
> > > > > On Behalf Of Ted Koch
> > > > > Sent: Wednesday, October 17, 2012 8:38 AM
> > > > > "Open
> > With"
> > > > > menus
> > > > > You can add not a column to the collection. Check this.
> > > > > http://www.usdoingstuff.com/2012/06/15/add-column-to-grid-in-e
> > > > > pi
> > > > > co
> > > > > r-
> > > > > sp
> > > > > ecific
> > > > > ally-to-chart-tracker/
> > > > > From: mike.numbers <mnumbers@...
> > > > > Sent: Wednesday, October 17, 2012 8:33 AM
> > > > > Subject: [Vantage] How do I add a custom program to the "Open
With"
> > > > > menus
> > > > > I had to create a custom dashboard version of Part Transaction
> > > > > History because a field we needed was not part of the collection.
> > > > > How do I add my new version of this to all of the "Open With"
> > > > > menus that currently have the Epicor version of this program?
> > > > > 9.04.507a
> > > > > Mike
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> > > > > You must have already linked your email address to a yahoo id
> > > > > to enable
> > > access.
> > > > > (1) To access the Files Section of our Yahoo!Group for Report
> > > > > Builder and Crystal Reports and other 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
http://groups.yahoo.com/group/vantage/files/>
> > > > > <http://groups.yahoo.com/group/vantage/files/>
> > > > > (2) To search through old msg's goto:
> > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > > [Non-text portions of this message have been removed]
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > > > must have already linked your email address to a yahoo id to
> > > > enable
> > access.
> > > enable
> access.
> > must have already linked your email address to a yahoo id to enable
access.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
