How can I execute a BAQ from code using a list type parameter?
In the BAQ designer I have this option to add values:
How can I do it with code? I’m using this code to execute the BAQ
		// Declare and create an instance of the Adapter.
		DynamicQueryAdapter adapterDynamicQuery = new DynamicQueryAdapter(this.oTrans);
		adapterDynamicQuery.BOConnect();
		// Declare and Initialize Variables
		string BAQName = "FiscalPeriod";
		Ice.BO.QueryExecutionDataSet ds = new Ice.BO.QueryExecutionDataSet();
		// Add Parameter Rows
		// Definition: AddExecutionParameterRow(string ParameterID, string ParameterValue, string ValueType, bool IsEmpty, Guid SysRowID, string RowMod)
		// Possible ValueTypes: nvarchar, int, decimal, date, datetime, bit, uniqueidentifier, bigint
		// IsEmpty indicates if your passed value Is Empty because if it is, you can define in your params to use a default value if empty.
		// Typically you use string.IsNullOrEmpty(yourValueVariable) but if you are hard coding a value then you can simply set it to false
		ds.ExecutionParameter.AddExecutionParameterRow("FiscalYear", "2016", "int", false, Guid.Empty, "A");
		ds.ExecutionParameter.AddExecutionParameterRow("FiscalPeriod", "10", "int", false, Guid.Empty, "A");
		// Call Adapter method
		adapterDynamicQuery.ExecuteByID(BAQName, ds);
		// Lets Loop through our results
		if (adapterDynamicQuery.QueryResults.Tables["Results"].Rows.Count > 0)
			dgDatos.DataSource = adapterDynamicQuery.QueryResults.Tables["Results"];
		// Cleanup Adapter Reference
		adapterDynamicQuery.Dispose();
		MainController.Cursor = Cursors.Default;
	} catch (System.Exception ex)
		ExceptionBox.Show(ex);
I believe that lists are handled by making a tilde (~) delimited string. You coud confirm this by enabling tracing and running your BAQ in the BAQ designer, then look at the Where clause generated.
Thanks for your answer, in the tracing a parameter is added for each value in the list so I solved it this way
foreach(var item in parameterList)
     ds.ExecutionParameter.AddExecutionParameterRow("Departments", item, "nvarchar", false, Guid.Empty, "A");
Hello,
Can you share with us the complete dynamic query code when using the parameter list from baq?
Thank you.
Here’s how I’m doing it from a classic screen customization.
private DataTable ExecuteSMIJobs(IEnumerable<string> jobNums)
    using (DynamicQueryAdapter dynamicQueryAdapter = new DynamicQueryAdapter(UD03Form))
        dynamicQueryAdapter.BOConnect();
        var queryExecutionDataSet = new QueryExecutionDataSet();
        foreach (var jobNum in jobNums)
            queryExecutionDataSet.ExecutionParameter.AddExecutionParameterRow("JobNums", jobNum, "nvarchar", string.IsNullOrEmpty(jobNum), Guid.Empty, "A");
        dynamicQueryAdapter.ExecuteByID("SMIJobs", queryExecutionDataSet);
        return dynamicQueryAdapter.QueryResults.Tables["Results"];
