I have a BAQ report working almost 100% to requirements. Unfortunately, when I use a “dynamic” StartDate and/or EndDate parameter (for example, “Last Monday”), it comes through as “&Mon-1” in my report header. I am trying to construct a string in the header that shows “Date range: <StartDate> to <EndDate>”. Works great when I supply a date, but dynamic values blow it up. When I supply a static date such as 4/1/2023, it comes through as “2023-04-01T00:00:00”, which FormatDate handles fine – chokes on the dynamic, obviously.
I am thinking I will need to add some code to the functions in the RDL. Anyone have some to share?
That’s definitely an improvement over “#Error”, but I was hoping there’d be a way to translate the dynamic date parameter “Mon-1” (not sure why coded ampersand is in the output) to an actual date (right now that would be 5/15/2023).
OK, yeah – I could see how to make that work. I’ll just manually pair up the dynamic date expressions Epicor presents in the report dialog with the BAQ constants from the designer interface. I suppose I hoped this could be brought across without bending myself over backwards, but here we go. Thank you for the inspiration!
This is how I’ve been handling it. It isn’t pretty or elegant. I also haven’t seen a measurable performance impact on the BAQ, the various latencies swamp out any difference.
At first I thought I’d get around to a solution that feels less clunky. After thinking about it for a while I switched to; I’d rather do this and get reliable results, than try to map out their homegrown date offset referencing and end up with something that could break when they change it.
Got around to implementing this, and it was even easier than I thought (I misinterpreted the suggestions a bit initially). The only drawback to piggybacking on an existing dataset is if you select a date range that returns no rows, you also get no date values – but at least it still runs and just shows a date of Jan 1st 1AD.
The solution, if it helps anyone in the future, would be to add another BAQ to your Data Definition that only brings your parameters to the report, independent of other datasets. I will likely not even bother with this because this should never happen under normal usage, doesn’t bomb, and in the past I have had to re-create RDLs from scratch after fussing around with the data definition and I am really ready to close the book on this one.
