Highlight duplicate value in Dashboard
Hi all,
I have a Dashboard where the lines rarely occur twice, but if they do the user should know about it. Therefore, I need the dashboard to be able to highlight duplicate fields. I cannot figure out how to set the filter values in the dashboard to create this highlight.
The dashboard I have is for sales order lines with the bin location of the part. I have already added filters in the BAQ to only show bins in the preferred warehouse. however, there is a rare occasion where the parts are briefly kept in two different bins (because of physical size of the part, i.e. they are too big and cannot fit into one bin). In this case, my Dashboard shows two bin locations for the same order line. I want the dashboard to highlight these duplicate occurring lines.
If anyone can solve this I’d be really grateful.
Many thanks
hymal7
Conceptually, what I envision is some sort of “second pass” over the original dataset. You might be able to accomplish this by using a subquery as your first pull of data encapsulated by a top level query. In the top level query, you would have the subquery results available and could perform a calculated field of each of the results, i.e. you could use a count + partition by over rows. If the count is greater than 1, you could set a highligher on that row.
In the BAQ, make a sub-query that is essentially the main query, but has a calc field with a COUNT() to count the number of lines.
Then in the Dashboard use a row rule to hightlight any row who’s count value is > 1.
Also, Don’t know what it would do to performance. But if you make every field of the the top level of the BAQ as ‘Group By’, you’d never get any repeats
This is only if you just don’t want to see them. If you need to find them to take some action then, this ain’t for you.
If you a calculated field that is simply 1, then do a
sum(calculated field) over (partition by x)
(syntax might be wrong, but you get the point)
with x probably being another calculated field where you concatenate the order number, line, the sum for those lines would be NOT 1. So you could add your row condition for <> 1.
This is one thread where they talk about this feature.
This is almost what @Aaron_Moreng said, except I don’t think you need a sub query.
The same thing could be accomplished with sub queuries instead.
He’s looking for almost the same. The row will have different bin locations.
This is good and then you can add your calc field with this kind of query.
I would investigate why the doubles are occurring? Is it a join issue or are there really multiple items.
I think the group by would not be a huge performance hit.
multiple bin locations.
Another option would be to concatenate all the bins, and return it as a single field
Hey, I have a question quite similar.
If parts are repeatable with different suppliers then how we can highlight them in the Epicor dashboard?
Make a calculated field that counts the duplicates (using whatever rules you make up) and highlight rows with the count greater that 1.
Calculated field
count(1) over (partition by table.company, table.partnumber, table.whateverOtherFieldsYouWantToPartitionBy)
Then set up view rules in your dashboard.
