I’m not used to do this. What I would probably do, even more if I see that
Epicor program seems to overlap my customisation, I would probably freeze
the sheet completely, like by putting false in the enable properties. Then
I would create my own dashboard I would put in a custom sheet that would
show only the information my employee needs.
*Amélie Pelletier*
*Analyste Programmeur / Program analyst*
[image: cid:image001.jpg@01CD5525.2091A820]
*230, Boulevard Nilus-Leclerc*
*L'Islet, Québec (Canada)*
*G0R 2C0*
*Téléphone: 418-247-3986 ext. 2390*
*Fax: 418-247-7925*
amelie.pelletier@... <
brigitte.savoie@...>*
*P* Est-ce nécessaire d’imprimer ce message?
*Please consider the environment before printing this email**.*
*De :*
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com]
*Envoyé :* 2 octobre 2014 11:02
*À :*
*Objet :* RE: [Vantage] "Hiding" fields in "listbox" customization on Job
Tracker not working. Vantage 8.03
It’s a list “sheet†but if I put “False†in the properties, all that does
is freeze the control and I need for them to be able to “scroll†the list
pane left and right to see the other fields. I just want to hide two or
three of the fields in the list sheet pane and it DOES work if there isn’t
a job pulled up but as soon as I pull a job up, the hidden fields come
back. Strangely enough, I did the SAME thing in the “Labor Transactionâ€
list pane and it worked perfectly (meaning the hidden fields STAYED
hidden).. Any ideas???
vantage@yahoogroups.com>]
*Sent:* Thursday, October 02, 2014 9:36 AM
*To:*
*Subject:* RE: [Vantage] "Hiding" fields in "listbox" customization on Job
By a list box, do you mean an ultracombobox? Or do you mean a sheet named
list.
If it’s the ultracombobox, you can just take it outside the screen (-100
-100 position in the parameters sheet).
If it’s a list sheet, then you go on the properties of the sheet an at
enabled propertie, you put false.
*Amélie Pelletier*
*G0R 2C0*
*Fax: 418-247-7925*
*De :*
*Envoyé :* 2 octobre 2014 10:34
*À :*
Jose, how can this be done on a “list†field????? That’s the only place
I’m having an issue..The only options I have are to “hide†it and “read
onlyâ€â€¦.
*Sent:* Thursday, October 02, 2014 9:27 AM
*To:* Vantage
*Subject:* Re: [Vantage] "Hiding" fields in "listbox" customization on Job
No, not a bug but "Working as Designed" there is a lot of logic behind some
of the onscreen fields so even if you hide them they'll come back
sometimes. There are a few work arounds
a) Position them at -100,-100 (out of sight out of mind)
or
b) Remove the Epicor Binding to the Field, then Hide the Actual Field.
*Jose C Gomez*
*Software Engineer*
T: 904.469.1524 mobile
E:
jose@...
http://www.josecgomez.com
http://www.linkedin.com/in/josecgomez> <
http://www.facebook.com/josegomez>
http://www.google.com/profiles/jose.gomez>
http://www.twitter.com/joc85>
http://www.josecgomez.com/professional-resume/>
http://www.josecgomez.com/feed/>
On Thu, Oct 2, 2014 at 10:22 AM, Mike Abell
mabell@... [vantage] <
vantage@yahoogroups.com> wrote:
I’ve created a customization that “hides†several fields under the
“operations list†in Job Tracker, specifically the ones that deal with
labor rates. I save the customization and enable it and go to use it and
before I select a job to view, the fields that I hid in the list are indeed
not there. However, as soon as I pull up a job to view, they reappear. Is
this a bug?????
*Mike Abell*
*Information Technology ManagerFlexial - BOA Group - Cookeville, Tennessee*
Office: 931.432.8408
Mobile: 615.418.3055
email:
MAbell@...
