Hide Menu in Menu Maintenance
Hi Guys,
Is there anyway to hide the menu like mine Part? as I have already Part(New) as that have legend in it, so the original Part Maintenance page I want to hide.
@Ziqqie_ringstorm Part is everywhere. You should make yours a custom layer on Part so that will come in all of the open with places.
But if you ant to hide Part I assume it can be disabled, but i have never done that.
Hi @gpayne , I just wanted to hide the Part I only, I see is it because it is default by EPICOR? as I cant delete the Menu itself
@Ziqqie_ringstorm That is not an approach that will work. Make a custom layer on top of Part.
@gpayne can guide me through?
If you copy the system part menu to current company, the system menu item will be hidden on the next launch and only the copy will show. You would have to do this for every occurrence of the Part menu in each company. But as Greg said if all you are doing is customizing it, then you don’t need a separate menu item, you can just apply your customization to the existing part menu items.
It’s usually easier to create a customization for the screen. But you still have to go into Menu Maintenance after that and set it to use the customization.
You have to do that in several spots, which you can find when you look at the security tab:
If you need more fine tuning, you can just set Part to appear only for certain groups (as also listed above). The advantage to that part is there is only one security entry for all the places part appears.
yes, I’m customizing it but the issue right now is I can’t set the customization, the drop down for customization has been greyed out.
Go to Actions I think, Copy to Current Company.
Hi @klincecum it works! thank you and thank you others for helping me also
