Help with printing labels
Not sure if this will help, but when I'm creating odd-sized label "reports"
in Crystal, I will hook up (physically or shared) the barcode printer to my
PC that I'm developing on and make it the default printer.
After you do so, in Crystal, when previewing the label the page size should
automagically adjust since it's your default Windows printer. Then, make
sure at that time none of your label's fields are trailing off to the side
or bottom.
HTH
Mike Numbers
Sent: Wednesday, December 12, 2012 11:41 AM
Subject: RE: [Vantage] Help with printing labels
On the page setup in CR, I had to change the orientation to landscape. The
page size defaulted to letter. I then changed the size to custom. I do
not see (or at least recognize) any sizes close to my label of 3 1/2 inch.
CR version 11.5.3.417
Behalf Of
Vic Drecchio
Sent: Wednesday, December 12, 2012 11:00 AM
You didn't mention it, so: Have you adjusted the Page Size in CR?
Behalf Of
mike.numbers
Sent: Wednesday, December 12, 2012 10:45 AM
Subject: [Vantage] Help with printing labels
I have a crystal report that prints labels using the wizard. I am trying to
print the labels on a Brother QL-580N label printer. The problem I have is
the labels are printing with a blank label in between each of my good
labels. I think this is telling me the report is feeding a wider line to the
printer. My label is 3 1/2 inches in width. Any ideas on how I can correct
this?
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2221 / Virus Database: 2634/5453 - Release Date: 12/12/12
I have a crystal report that prints labels using the wizard. I am trying to print the labels on a Brother QL-580N label printer. The problem I have is the labels are printing with a blank label in between each of my good labels. I think this is telling me the report is feeding a wider line to the printer. My label is 3 1/2 inches in width. Any ideas on how I can correct this?
mike.numbers
this?
Vic Drecchio
Behalf Of
mike.numbers
this?
