Thanks Joshua
Changed to ((Epicor.Mfg.Core.Session) ReceiptEntryForm.Session).AppServer and compile error is gone - haven't tested yet
--- In vantage@yahoogroups.com, Joshua Giese <jgiese@...> wrote:
> ((Epicor.Core.Session) ReceiptEntryForm.Session).AppServer
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> From: "Dan Sirow" <dansirow@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, May 30, 2013 12:35:05 PM
> Subject: [Vantage] Re: Help with C#
> Thanks for the help but I'm missing something.
> I have the session dll(s) but still get the error.
> How do I "cast form.session into epicor.core.session"?
> Thanks again for the help !
> --- In vantage@yahoogroups.com , Joshua Giese <jgiese@> wrote:
> > If that were the case it would give you a casting error of obj to str. The issue lies in the difference of loose casting of VB vs C#. You need the session dll and a cast on the session for C#
> > Joshua Giese
> > CTO
> > From: "Joe Englert" <englertj@>
> > Sent: Thursday, May 30, 2013 11:45:44 AM
> > Subject: RE: [Vantage] Help with C#
> > I think you'll need to add ".ToString();" to the end of your C# line. Currently, it's trying to pass an AppServer into a String.
> > From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of Dan Sirow
> > Sent: Thursday, May 30, 2013 12:33 PM
> > Subject: [Vantage] Help with C#
> > I'm converting customizations from VB to C#. Having trouble with the following simple line that I used to determine if I'm on my test server as a file path is different:
> > VB: Dim AppServer As String = ReceiptEntryForm.Session.AppServer
> > C#: string AppServer = ReceiptEntryForm.Session.AppServer
> > Getting 'object' does not contain a definition for 'AppServer"
