HELP URGENT Error 533
Thank You. The set location some how got changed.
Dina
Sent: Wednesday, October 02, 2002 11:29 AM
Subject: RE: [Vantage] HELP URGENT Error 533
Open up the document in Crystal and Verify the data base. At which
point
you will probably have to "SET THE LOCATION" That is enter the file
path
for your Vantage work directory. The Vantage work directory should be
the
same for all workstations. Let me know if you need help, I'll walk you
through it.
Shirley
Sent: Wednesday, October 02, 2002 12:17 PM
Subject: [Vantage] HELP URGENT Error 533
I need the expertise of the group.
When someone goes to print an invoice, the invoice the prints and
prints previews I receive and error 533 - and that it could not find
the dbf file.
This only for orders and invoices. The PO's print okay and so does
reports.
This is from all computers not just one workstation.
Dina
Yahoo! Groups Sponsor
ADVERTISEMENT
and
http://docs.yahoo.com/info/terms/
the dbf file.
reports.
Dina
Open up the document in Crystal and Verify the data base. At which point
you will probably have to "SET THE LOCATION" That is enter the file path
for your Vantage work directory. The Vantage work directory should be the
through it.
Shirley
the dbf file.
reports.
Dina
ADVERTISEMENT
Sounds like you might be using a modified crystal report form. If so, open
the form up in Crystal Reports and change the database location to C:
\Vntgwork (for version 5.0), C:\Vntgwk51 (for Version 5.1), and C:\Vntgwk52
(if you are on Version 5.2). To do this, go to the top menu in Crystal
Reports and select Database, then Set Location.
Mike Moloney
(Embedded "dhieber_vamco" <dhieber@...>
image moved 10/02/2002 12:16 PM
to file:
pic17549.pcx)
Please respond to vantage@yahoogroups.com
cc: (bcc: Michael J. Moloney/USWIN01/Power/ALSTOM)
Security Level:? Internal
the dbf file.
reports.
Dina
ADVERTISEMENT
(Embedded image moved to file: pic29556.gif)
CONFIDENTIALITY : This e-mail and any attachments are confidential
and may be privileged. If you are not a named recipient, please
notify the sender immediately and do not open any attachments hereto,
disclose the contents of this e-mail or the attachments if any
thereto, to another person, use it for any purpose or store or copy
the information in any medium.
