Help on data to text field
thanks again - I've tried both options but keep getting the JIT Errors (Just In Time)
Private Sub IssueReturn_AfterFieldChange(ByVal sender As object, ByVal args As DataColumnChangeEventArgs) Handles IssueReturn_Column.ColumnChanged
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "LotNum"
Dim partNum As String = args.Row("PartNum")
Dim lotNum As String = args.row("lotnum")
Dim adppartbin As PartBinSearchAdapter = New PartBinSearchAdapter(IssueMaterialForm)
adppartbin.BOConnect()
Dim varpartbin As Epicor.Mfg.BO.PartBinSearchDataSet = adppartbin.GetPartBinByLot(partNum,lotNum)
dim tempvar as EpiNumericEditor = adppartbin.PartBinSearchData.tables("partbin").rows(0)("onhandqty")
dim ohq as EpiNumericEditor = Tempvar
ohq=CType(csm.GetNativeControlReference("c1a938ad-5cce-49a0-8c6e-f8c4df83eb91"),EpiNumericEditor)
'//Dim [edvVarName] As EpiDataView = CType(oTrans.EpiDataViews("IM"), EpiDataView)
'//[edvVarName].dataView([edvVarName].Row)("OnHandQty") = tempvar
adppartbin.Dispose()
Case Else
End Select
End Sub
End Module
408
Within the issue material field there is an onhand field that is not quite working as it should. therefore I'm trying to populate either that field (qtyonhand) or a unnattached field with the lot onhand qty from the partbin table. This is what ive done so far, but I'm having trouble returning the onhandqty value - what am i doing wrong? :
Case "LotNum"
Messagebox.Show ("fired OK","Fired",MessageBoxButtons.OK, MessageBoxIcon.Warning)
up to here it seems to work
below is what I have tried to populate the data:
'//args.row("onhandqty") = adppartbin.partbinsearchdata.tables("onhandqty").rows(0)
'//txt_Onhand_31269ae9_a2b8_41a8_b7d7_a473cead6ee9.text = adppartbin.partbinsearchdata.tables("onhandqty").rows(0)
Case Else
End Select
End Sub
Go into customization
Go into object explorer
Middle tab - data objects.
Find the table/field in the list and click on it.
In the right frame you'll see how to get to the table
It will display something like this:
Dim [edvVarName] As EpiDataView = CType(oTrans.EpiDataViews("UD01"),
EpiDataView)
Dim [VarName] As String =
[edvVarName].dataView([edvVarName].Row)("Character02")
What you'll want to do is something like this.
EpiDataView)
[edvVarName].dataView([edvVarName].Row)("Character02") = <your value
Of Rupert
Sent: Thursday, September 02, 2010 6:12 AM
Subject: [Vantage] Help on data to text field
408
Case "LotNum"
Case Else
End Select
End Sub
Thanks for that.
What about if its a non-defined text box etc? ie no data connection. The reason I ask is as the form is based on the "IM" data it's difficult to easily maniplulate
> EpiDataView)
> EpiDataView)
> Of Rupert
> 408
> Case "LotNum"
> Case Else
> End Select
> End Sub
Then you need to do something like this, replacing the GUID with your
own and changing the EpiNumericEditor to the correct type for the field.
dim myVariable as EpiNumericEditor
myVariable
=CType(csm.GetNativeControlReference("bdda2b2b-d8b4-4c89-a9e1-77466d34d7
fc "),EpiNumericEditor)
Of Rupert
Sent: Thursday, September 02, 2010 8:43 AM
Subject: [Vantage] Re: Help on data to text field
Thanks for that.
easily maniplulate
> EpiDataView)
> EpiDataView)
Behalf
> Of Rupert
> 408
that
trouble
> Case "LotNum"
> Case Else
> End Select
> End Sub
