Help needed with Vantage 5.2
Thanks all but unfortunately no luck.  What we have discovered now is that it has something to do with the ability to open or use the database.  When we try to install the Vantage client on the workstations everything is fine until it starts to install the Progress database and we get an error message saying that it can not "use" the F:\progress\netinstall\setup.exe.  However, I can go to the F:\progress\netinstall and run the setup.exe.  It seems to run fine but ends without showing a completed install.  There are no messages in the event viewer.  I'm looking for my notes on the original install to see if we are missing something.  Hopefully I will find them.  It still installs on the server(s) just fine and most users can still get to it via remote desktop.  I was the IT contractor for this client back in the day so I'm going onsite with their current IT support people to try to fix this so again, any help from any one's memory banks would be greatly appreciated.  When we retire this system I think we will donate it to the Smithsonian.  :- )
Thank you all for trying.
Virginia
--- In vantage@yahoogroups.com, <vpsmith63@...> wrote:
Btw...loved the "Solutions for Epiday Living".  :-)
--- In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:
Virginia –
Try reading the Vantage.mfg file from one the machines with a working installation. You can use NotePad to read the contents of the .mfg file. The settings in this file need to be used when adding new workstations. You will need to know the server name/IP address, working folder, and service name/port numbers for the new workstation install.
When running the setup.exe program to install a new machine make sure you answer the prompts with the information in the vantage.mfg file.
Please let me know if you have 64bit computers or Windows 7 machines I can send you the instructions off-list for that type of installation. Same with ODBC based reports.
HTH,
Calvin Dekker
Office: 630-672-7688 Ext. 1484
Email: calvin@...<mailto:calvin@...>
http://www.codabears.com<http://www.codabears.com/>
[cid:image001.jpg@01CEB328.B19BE210]<http://www.codabears.com/>
Solutions for Epiday living.
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of vpsmith63@...
Sent: Monday, September 16, 2013 8:05 PM
Subject: [Vantage] help needed with Vantage 5.2
Yes, Vantage 5.2...
Late last week the server hiccuped and ever since Vantage will not work. The work-around is to create remote desktop sessions to the server and users log in that way. only drawback is that printing does not work because most printers are locally attached. With a little IT digging we have discovered that the problem is that the progress database application does not load. There is no error message to indicate there is a problem. The Vantage splash screen just disappers. We have also discovered that if we reinstall the Vantage client then double click on the desktop icon that is created during the install Vantage works. However when you install it on the next computer it breaks the first install. Basically only one install can work at a time (unless you use the remote desktop session). Has anyone seen this behavior before? We are at a loss as to what might fix this. Shipping is completely down because the lable printers can't print. Any help would be greatly appreciated!!!
Thanks!
Virginia
Yes, Vantage 5.2...
Thanks!
Virginia
Virginia –
HTH,
Calvin Dekker
Yes, Vantage 5.2...
Thanks!
Virginia
 Thank you so much.  I will give this a try.  We have no Windows 7 or 64-bit computers at this moment.  But I may contact you for that info for future reference.
Virginia
Virginia –
HTH,
Calvin Dekker
Yes, Vantage 5.2...
Thanks!
Virginia
If I remember correctly, at the beginning of a new client install there was a check box for “Use workstation install as default install” (or something like that), and if you left that checked it messed with all of the workstations even the ones that previously had it installed. Maybe try a new install with that box unchecked.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Winter, Patrick
Sent: Tuesday, September 17, 2013 8:05 AM
Subject: RE: [Vantage] help needed with Vantage 5.2
When installing new clients in 5.2 the ‘Plant Floor.mfg’ and ‘Vantage.mfg’ files on the server get over written each time with whatever information you enter when installing a client.
If you fill out the screens exactly the same on the installation is all good.
If you don’t fill out all the installation screens the same the last guy wins.
Example if you install an office users but don’t install shop floor data collection the shop floor data collection gets set do a blank login and password. The office installation will work but the shop floor stations will no longer automatically log in.
This is just one idea which I hope helps you out, I haven’t been on 5.2 for 10 or 12 years so this is the best I can come up with unless some other conversation jolts my memory.
Patrick Winter
Sent: Monday, September 16, 2013 20:05
Yes, Vantage 5.2...
Late last week the server hiccuped and ever since Vantage will not work. The work-around is to create remote desktop sessions to the server and users log in that way. only drawback is that printing does not work because most printers are locally attached. With a little IT digging we have discovered that the problem is that the progress database application does not load. There is no error message to indicate there is a problem. The Vantage splash screen just disappers. We have also discovered that if we reinstall the Vantage client then double click on the desktop icon that is created during the install Vantage works. However when you install it on the next computer it breaks the first install. Basically only one install can work at a time (unless you use the remote desktop session). Has anyone seen this behavior before? We are at a loss as to what might fix this. Shipping is completely down because the lable prin ters can't print. Any help would be greatly appreciated!!!
Thanks!
Virginia
Virginia –
HTH,
Calvin Dekker
Yes, Vantage 5.2...
Thanks!
Virginia
