Help. Labor Entry causing the client and AppServer to hang
We have exactly the same problem on Vantage 8.03.406. Logged a call with Epicor in June 2010 and it is still open.....
--- In vantage@yahoogroups.com, "markbetts66" <markbetts66@...> wrote:
> Hi,
> When posting labor against a particular assembly within a job its causing the both the client + AppServer to hang and high CPU usage on the SQL server.
> Has anyone else had this issue? Or any ideas what may be causing it?
> Thanks,
> Mark.
Hi,
Mark.
What version are you on?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of markbetts66
Sent: Monday, March 07, 2011 11:30 AM
Subject: [Vantage] Help. Labor Entry causing the client and AppServer to hang
Hi,
Mark.
Hi,
408B SQL
> Hi,
> Thanks,
> Mark.
Do you have any custom code that touches the Labor tables?
I've seen Epicor hang a number of times when it finds malformed records. Try
viewing the record with a query and compare it to a good one.
On Mon, Mar 7, 2011 at 1:59 PM, markbetts66 <markbetts66@...> wrote:
> Hi,
> 408B SQL
> Of markbetts66
> hang
> > Hi,
> server.
> > Thanks,
> > Mark.
We are on 8.03.409C SQL
We have seen jobs with no schedule date shown (although they were scheduled). I know this caused MRP to hang and may also have caused some labor issues...We have a process to reschedule those jobs (a BAQ finds those without a date).
Sent: Monday, March 07, 2011 1:00 PM
Subject: [Vantage] Re: Help. Labor Entry causing the client and AppServer to hang
Hi,
408B SQL
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...> wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of markbetts66
> Hi,
> Thanks,
> Mark.
Hi,
The labor entry screen is Vanilla as it comes. Will try comparing the offending assembly record against the good ones, thanks.
> > Hi,
> > 408B SQL
> > Of markbetts66
> > hang
> > > Hi,
> > server.
> > > Thanks,
> > > Mark.
Mark;
You touched a nerve.
We struggled with this issue since 8.03.408 and it was listed in the patch list twice that I know of as having been fixed. I also got (3) one-off fixes that did not work. It comes and goes, with no rhyme or reason. We replaced swittches, computers, re-schduled jobs etc. and would be good for a while but it would always come back.
We had three weeks of crashing (4) times a day last month and pleaded with Epicor to send out an expert. What came next was a miracle.
We got a "One-Off" fix that corrects this known issue, and it worked!
We have not had a single crash in two weeks! Not even a flutter.
Contact support and reference:
Fix is in SCR 67017 where you replace the "Write.r" for for JobOper trigger.
I hope helps you as much as it did our company!
Regards,
George Hicks
> Hi,
> Thanks,
> Mark.
Thanks George,
We have contacted Epicor and requested the SCR.
--- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@...> wrote:
> Mark;
> Regards,
> George Hicks
> --- In vantage@yahoogroups.com, "markbetts66" <markbetts66@> wrote:
> > Hi,
> > Thanks,
> > Mark.
