Here is a post I made which explains it in more detail
http://www.usdoingstuff.com/2011/07/06/accessing-the-current-session-in-a-customization/
*Thanks!*
*Jose C Gomez*
Software Engineer
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Thanks!*
*Jose C Gomez*
Software Engineer
E: jose@...
On Wed, Jul 6, 2011 at 7:51 PM, Jose Gomez <jose@...> wrote:
> You need to bring in the Core.Session and Core.BLConnect dll's Yo also need
> to cast your object to a session as ((Session)UDForm.Session).COmpany ID
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
> On Wed, Jul 6, 2011 at 5:43 PM, edgarj.lopez <edgarj.lopez@...>wrote:
>> Hello Group
>> I need a little help in c #
>> I have developed some customizations in Visual Basic, on Vantage and E9.
>> I am currently developing some customizations in c #
>> but I have not really worked much with this language.
>> The problem that I have is that
>> I do not understand how to reference the companyID in the program
>> Here I leave a part of the program code
>> private static void btnSupplier_Click(object sender, System.EventArgs
>> args)
>> // ** Place Event Handling Code Here **
>> string WhereClause = "Company = '" + UD08Form.Session.CompanyID + "'";
>> bool recSelected = false;
>> DataSet dsSearch = new DataSet();
>> dsSearch = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,
>> "VendorAdapter", out recSelected, true, WhereClause);
>> if (recSelected)
>> edvUD08.dataView[edvUD08.Row]["ShortChar11"] =
>> dsSearch.Tables[0].Rows[0]["VendorId"];
>> edvUD08.Notify(new EpiNotifyArgs(oTrans, edvUD08.Row, edvUD08.Column));
>> txtSupplierName.Text = dsSearch.Tables[0].Rows[0]["Name"].ToString();
>> And the error sent by the compiler
>> Compiling Custom Code ...
>> ----------errors------------
>> Error: CS0117 - line 138 (1034) - 'object' does not contain a definition
>> for 'CompanyID'
>> ** Compile Failed. **
>> I do not understand why the error
>> if the statement is basically the same as in VB
>> Any help will be greatly appreciated.
>> regards
