From what ive tried...not too well..seems very limited, but then again I
haven't ran through them all.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Brian W. Spolarich
Sent: Thursday, July 16, 2009 8:36 AM
Subject: RE: [Vantage] HELP! BAQ Calculated field sytax error
Can someone educate me as to how the syntax of the BAQ calculated field
statements relates to the ABL/4GL syntax defined in the Reference Guide
and handbook on the Progress web site?
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
www.advancedphotonix.com
Behalf Of Gary Parfrey
Sent: Thursday, July 16, 2009 9:31 AM
You do not need the end statements. Remove them and just use the nested
if then else statements
Gary
Behalf
Of Dan Godfrey
Sent: 15 July 2009 18:17
I thought about that and it does not make a difference here. I have
even tried parenthesis around the conditions, like the following to no
avail.
If (PartRev.TLRMaterialCost > 0.0) Then
(PartMtl.QtyPer * PartRev.TLRMaterialCost)
Else
If (PartPlant.CostMethod = 'S') Then
(PartMtl.QtyPer * PartCost.StdMaterialCost)
Else
(PartMtl.QtyPer * PartCost.AvgMaterialCost)
End.
End.
Behalf
Of Mark Wonsil
Sent: Wednesday, July 15, 2009 10:10 AM
Dan wrote:
If not, copy and paste the formula into Notepad. Start with a simple
statement and then add items until you get an error.
Mark W.
Rob Bucek
FAX: (715)284-4084
-bws
Picometrix
bspolarich@...
Gary
Behalf
Of Dan Godfrey
avail.
Else
Else
End.
End.
Behalf
Of Mark Wonsil
Dan wrote:
> this is my code in a calculated field of a BAQ. I get aTry adding a period to your second to last End.
> syntax error. I can not see the error.
> If PartRev.TLRMaterialCost > 0.0 Then
> Else
> If PartPlant.CostMethod = 'S' Then
> Else
> End
> End.
Mark W.
