Hardware Specifications for 9.05 Server on Virtual Environment
Thanks for the advice, I will look into it as part of the overall development.
--- In vantage@yahoogroups.com, Zac Jason Woodward <zac@...> wrote:
> Based on that information it looks like you have a pretty solid starting point for your virtualization.
> I wish I had advice on the Hyper-v but I never did any of my Epicor 9 testing in hyper-v. Only suggestion is make sure you look into the advanced Hyper-V management tools if you believe think that you might add in another hypervisor later on. This will enable some similar features that VMWare offers.
> "Zac" Jason Woodward
> Network Administrator
> Intermountain Electronics, Inc.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Creating customer confidence through extraordinary service and experienced industry experts.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark
> Sent: Friday, March 25, 2011 9:48 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Hardware Specifications for 9.05 Server on Virtual Environment
> Hi
> From the imformation given to us by our supplier (who will also configure the system) the way we are going to use Hyper-v will fall into the right requirements.
> The allocation of RAM will be 16Gb per physical server with the Epicor VM using all the resources of 1 server, the other server will run the other VM's, Each server will also act as failover if one of them has "issues" The FC is part of the SAN starter kit, the system has no single point of failure which was our goal.
> It is expensive @ £32k but it gives us the resources and protection we require.
> I appreciate what you say with the RAM, Epicor loves its memory, we will be testing before deployment and if more is required there is provision to add it.
> Mark
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Zac Jason Woodward <zac@> wrote:
> > Win 2008 Enterprise 64Bit licensed for 4 VMs per copy
> > Something I was told by the MS rep for Dell is the VM licenses are only valid if you are running Hyper-V. Microsoft licenses the OS in a very specific manner.
> > In a cost saving suggestion make sure you want to commit to using FC. FC is more expensive than alternatives such as 10 gig Ethernet. I would recommend a minimum of 32 gig RAM. You will be surprised how fast it gets used. Our environment is licensed for around 35 users and 905 our RAM usage went up from 8 gig to 12 gig. Going 16 gig RAM on the hypervisor isnt going to leave you a lot of space for other virtual machines.
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark
> > Sent: Friday, March 25, 2011 1:58 AM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Hi
> > We have just spec'd out a new server environment with Epicor 9 in mind
> > (we are on V.8.03.405a Progress at the moment 19 users maybe more soon)
> > this is 2 servers and a SAN.
> > 2 x Xeon X5650 2.66Ghz 6 core (Per server) 1 server Epicor 1 for
> > everything else16Gb Ram (per server)HP Storage Works P2000 G3 SAN
> > Starter Kit which comes with (Dual FC controller, 24-drive bay SFF
> > chassis, (2) 8-port 8 Gb switches, (4) 8 Gb HBAs, SFPs and cables,
> > Storage Optimization Application (SOA) software)12 x 600GB 15k SAS HDD2
> > x Win 2008 Enterprise 64Bit licenced for 4 VMs per copy
> > We put this spec to our Epicor Reseller and they agreed this would be
> > sufficient to run E9 when we upgrade
> > Mark--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Doma Reddy <domareddy@> wrote:
> > > I am Planning to Build the 9.05 Server on the Virtual Environment, Can
> > someone give me Hardware specification for 9.05 to have a good
> > performance.
> > > Thanks,
> > > Doma.
Â
I am Planning to Build the 9.05 Server on the Virtual Environment, Can someone give me Hardware specification for 9.05 to have a good performance.
Â
Doma.
Doma,
can you provide user count expected and MES stations
thanks
--- In vantage@yahoogroups.com, Doma Reddy <domareddy@...> wrote:
> Â
> Â
> Thanks,
> Doma.
Depends on the number of consecutive users and how big your current DB is.
Only recommendation I can make at this point is do not use VMWare ESXi as does not perform well with progress. ESX does fine from what I understand.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Doma Reddy
Sent: Thursday, March 24, 2011 11:29 AM
Subject: [Vantage] Hardware Specifications for 9.05 Server on Virtual Environment
Doma.
Hi
performance.
> Thanks,
> Doma.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Hi
Mark--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Doma Reddy <domareddy@...> wrote:
performance.
> Thanks,
> Doma.
Hi
Mark
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Hi
> Mark--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Doma Reddy <domareddy@> wrote:
> performance.
> > Thanks,
> > Doma.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Hi
Mark
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Zac Jason Woodward <zac@...> wrote:
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Hi
> performance.
> > Thanks,
> > Doma.
