HandHeld Customization
Sent from my Verizon Wireless BlackBerry
Date: Mon, 16 Nov 2009 10:31:30
To: <vantage@yahoogroups.com>
Subject: RE: [Vantage] HandHeld Customization
Make sure you go into menu maintenance and apply the customization, Then log
out and back in again to see the screen.
Gerry
Thomas
Sent: Monday, November 16, 2009 10:29 AM
Subject: [Vantage] HandHeld Customization
Ok I feel like an idoit. I created a customization on My Material Que to
include the order number and part description. I saved it as well. How ever
when I try to pull the custopmization in menu maintenece it is not there.
I'm missing a step somewhere, I can only see the customization in developer
mode. Any suggestions?
Ok I feel like an idoit. I created a customization on My Material Que to include the order number and part description. I saved it as well. How ever when I try to pull the custopmization in menu maintenece it is not there. I'm missing a step somewhere, I can only see the customization in developer mode. Any suggestions?
Deploying handheld and MES customizations are
different/convoluted/difficult than the main UI.
Here are some instructions I have:
1. Make appropriate customizations to screen and save changes as
normal.
2. Identify the Key and Calling App parameters and customizing the End
Activity Screen
Launch the screen in Developer Mode
Now click on the program you want to customize (F2 End Activity)
Write down the Key and Calling App parameters, you will need these
later
Key: Epicor.Mfg.UI.EndActvityEntry.dll
Calling App: Epicor.Mfg.UI.HHWorkQueue
Click OK
3. Create the Sub Process entry
Because this Handheld screen program is not attached to the standard
menu, you need to create a "dummy" menu id
Log into a standard 8.03 session
Go to System Management >> Utilities >> Sub Process Maintenance
Choose File >> New
Enter a unique Process ID (These all need to start with UD, i.e.
UDENDACT)
Enter a Name (i.e. Custom End Activity)
Parent Process = PROCESS
Give it a unique sequence number (i.e. 100, 200, 300, etc.)
Make sure the Enable checkbox is checked
Program Type = Non Menu Item
Program = Epicor.Mfg.UI.EndActivityEntry.dll (Browse to it or type it
in)
Customization = name of the customization you previously named (should
be in the drop-down
list)
Click Save and exit out of Sub Process Maintenance
4. Create a Process Calling entry
Go to System Management >> Utilities >> Process Calling
Maintenance
Choose File >> New
Process Called Reference = Epicor.Mfg.UI.EndActivityEntry
(Key value from section #2)
Called From = Epicor.Mfg.YI.HHWorkQueue
(Calling App from section #2)
Menu ID = UDENDACT (Menu ID create in section #3)
Save and close Process Calling Maintenance
5. Test the customization
Log OUT and then back Into Vantage and test the customization...
Of Thomas
I was able to run the sub process and the customization does now show in
vantage. For some reason the guns don't show the new customization and
yes I logged them out and back in.
Lee Otero
CSM / Technical Sales
8090 Woodland Dr.
Indianapolis IN 46278
www.accuratemfg.com <http://www.accuratemfg.com/>
CONFIDENTIALITY WARNING: This communication may contain trade secrets,
privileged or confidential information and is for the sole use of
Accurate and the intended recipient (s). Any unauthorized use or
disclosure of this communication or any attachment hereto is prohibited.
If you believe that you received this communication and any
corresponding attachment in error, please notify the sender and Accurate
immediately and delete it from your system.
Gerry
Thomas
Sub process maintenance is required for MES screens. But handheld screens
are configured in menu maintenance.
Gerry
Vic Drecchio
Sent: Monday, November 16, 2009 10:33 AM
normal.
Activity Screen
later
Click OK
Choose File >> New
UDENDACT)
in)
be in the drop-down
list)
Maintenance
Choose File >> New
Behalf
Of Thomas
