Patrick, on the Landing page, if you click the new Download button, and if necessary, continue clicking the Get More button until your full dataset is loaded, you can then filter on UD columns.
You can also pre-filter the results, then download all of the filtered records from the server, which then allows filtering on UD columns.
For example, in Job Entry. We have a lot of firm jobs, so I want to narrow down the Landing Page results even further. So I select the filter icon, then set Engineered = Is True, Complete = Is False. Then I click the new Download button, and that loads the filtered dataset. Once it’s fully loaded, you can filter by your UD column. This is new in 2023.2.
