Hi everyone,
We plan to update from 2023.1 to 2024.2 in early 2025.
While testing a 2024.2 Demo env., I noticed that many grids now disable links on the current selected row.
Is this a known issue?
Hi everyone,
Hi Vincent,
As far as I know, this is how IT IS. When you hover over BX, the UOM, you see how it changes to a pointer finger? You can click the BX then, if you select the row as you did AFTER you hovered on BX, it doesn’t let you click the ‘hyperlink’ portion.
Frustrating, but it is how it has been working for me the past year in Kinetic.
Hope that helps
The change is noticeable in Tracker menus. I opened an Epicor case. They are waiting for a response from the dev team.
Part Tracker 2023.1 - the BX link remains clickable once the row is selected
Part Tracker 2024.2 - the BX link is no longer clickable once the row is selected
