ewelsh
(Ed Welsh)
July 12, 2017, 7:45pm
1
I was wondering if anyone knows of an easy way to search for forms that use the generic columns(Character01, CheckBox01, Date01, Number01, ShortChar01). I tried Inspect.exe, spy++and other UI test tools but I cannot find the label or the fields with these names.
I queried the DB to determine what generic fields are being used in tables and I have a list. So instead of looking in the field help technical details for every control I was hoping there is an easy way to query the DB for this information. I am trying to document what was being used in E9 so I can replicate in E10.
Thanks for any help
Very interesting.
You can find the customization binary data stored on XXXChunk, inside Chunk column.
Problem is that the Chunk is BZiped and Hex Encoded…
poking around this will turn the “Chunk” data back into a string… You’ll need
NetSword.Common.ICSharpCode.SharpZipLib (nuget)
private string decompressString(string data)
try
int num;
MemoryStream stream = new MemoryStream(Convert.FromBase64String(data));
BZip2InputStream stream2 = new BZip2InputStream(stream);
byte[] buffer = new byte[0x3e8];
MemoryStream stream3 = new MemoryStream();
while ((num = stream2.Read(buffer, 0, 0x3e8)) > 0)
stream3.Write(buffer, 0, num);
stream2.Close();
stream.Close();
byte[] bytes = stream3.ToArray();
stream3.Close();
return Encoding.UTF8.GetString(bytes);
catch
return data;
So if you want to do this you can BO GenXData
run GetRows where typecode=“Customization”
This will get you all the customizations in the system, then loop through all the XXXChunkRows and run the XXXChuck through that decompression aglorithm. Then use RegEx or another method to see if “CharacterXX, ShortCharXX, NumberXX, appear in the string”
It will turn this
string myChunk= decompressString("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");
Into this
<CustomizationDS xmlns="http://tempuri.org/XMLSchema.xsd">
<xs:schema id="CustomizationDS" targetNamespace="http://tempuri.org/XMLSchema.xsd" xmlns:mstns="http://tempuri.org/XMLSchema.xsd" xmlns="http://tempuri.org/XMLSchema.xsd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata" xmlns:msprop="urn:schemas-microsoft-com:xml-msprop" attributeFormDefault="qualified" elementFormDefault="qualified">
<xs:element name="CustomizationDS" msdata:IsDataSet="true" msdata:Locale="" msprop:BuildVersion="9.05.702A">
<xs:complexType>
<xs:choice minOccurs="0" maxOccurs="unbounded">
<xs:element name="Controls">
<xs:complexType>
<xs:sequence>
<xs:element name="FormsID" type="xs:string" />
<xs:element name="ControlName" type="xs:string" />
<xs:element name="Key" type="xs:string" />
<xs:element name="ParentControlKey" type="xs:string" />
<xs:element name="ControlType" type="xs:string" />
<xs:element name="Company" type="xs:string" />
<xs:element name="Plant" type="xs:string" />
<xs:element name="DcdUserId" type="xs:string" />
<xs:element name="GroupID" type="xs:string" />
<xs:element name="ControlsID" type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="Properties">
<xs:complexType>
<xs:sequence>
<xs:element name="PropertyName" type="xs:string" />
<xs:element name="PropertyValue" type="xs:string" />
<xs:element name="DcdUserID" type="xs:string" />
<xs:element name="PropertiesID" type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:choice>
</xs:complexType>
</xs:element>
</xs:schema>
<Controls>
<FormsID>BAQReportForm</FormsID>
<ControlName>epicor.mfg.bo.transferorderentry.dll</ControlName>
<Key>EpiString.ExecutionPath*epicor.mfg.bo.transferorderentry.dll</Key>
<ParentControlKey />
<ControlType>AssemblyReference</ControlType>
<Company />
<Plant />
<DcdUserId />
<GroupID />
<ControlsID />
</Controls>
<Controls>
<ControlName>epicor.mfg.if.itransferorderentry.dll</ControlName>
<Key>EpiString.ExecutionPath*epicor.mfg.if.itransferorderentry.dll</Key>
<Company />
<Plant />
<DcdUserId />
<GroupID />
<ControlsID />
</Controls>
<Controls>
<ControlName>epicor.mfg.ad.transferorderentry.dll</ControlName>
<Key>EpiString.ExecutionPath*epicor.mfg.ad.transferorderentry.dll</Key>
<Company />
<Plant />
<DcdUserId />
<GroupID />
<ControlsID />
</Controls>
<Properties>
<FormsID>filterListPanel1</FormsID>
<ControlName>grdFilterList</ControlName>
<Key>3c83f81e-470d-4ade-9646-152b68de99f2-1</Key>
<PropertyName>ChildIndex</PropertyName>
<PropertyValue>0</PropertyValue>
<Company />
<Plant />
<DcdUserID />
<GroupID />
<PropertiesID />
</Properties>
<Properties>
<ControlName>Customization</ControlName>
<Key>2dcd1674-5e34-4d98-b493-c75747027376</Key>
<PropertyName>Script</PropertyName>
<PropertyValue>// **************************************************
// Custom code for BAQReportForm
// Created: 4/9/2015 1:45:56 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Epicor.Mfg.Core;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.Searches;
public class Script
// Begin Custom Code Disposal
// End Custom Code Disposal
private void BAQReportForm_Load(object sender, EventArgs args)
string orderList = BAQReportForm.LaunchFormOptions.ValueIn.ToString();
//data view for the order list
EpiDataView orderListDV = (EpiDataView)(this.oTrans.EpiDataViews["FilterList1"]);
//have to parse the orderList string to get the values
if(!orderList.Contains("~")) {
//add a row
orderListDV.dataView.Table.Rows.Add();
//set the default row value for the dataview
orderListDV.Row = 0;
//set the value order list value in the table if there's only one
orderListDV.dataView.Table.Rows[0]["TFOrdNum"] = orderList;
//if there are multiple order numbers in the order list
else if(orderList.Contains("~")) {
//put the order numbers into a string array
string[] orderNums = orderList.Split('~');
//loop through the string array and set each value on the grid
for(int i = 0; i < orderNums.Length; i++) {
//add a row
orderListDV.Row = i;
//set the order number value
orderListDV.dataView.Table.Rows[i]["TFOrdNum"] = orderNums[i];
</PropertyValue>
<Company />
<Plant />
<DcdUserID />
<GroupID />
<PropertiesID />
</Properties>
<Properties>
<PropertyName>Language</PropertyName>
<PropertyValue>CSharp</PropertyValue>
<Company />
<Plant />
<DcdUserID />
<GroupID />
<PropertiesID />
</Properties>
</CustomizationDS>
ewelsh
(Ed Welsh)
July 12, 2017, 9:54pm
4
That worked great,
Thanks you just saved me a whole lot of time and headaches
This is a cool thread. Does any of this apply to e10?
Yes @Chris_Conn all of it applies to e10
Jose C Gomez
Senior Software Engineer
Hally
(Simon Hall)
July 14, 2017, 7:25am
7
I have to say that is a really great question, and excellent answer. Thanks for the contribution.
