I know that you can add logos to the different Report Styles but wondering if there’s a way to do it globally to ALL forms at the same time, like a Company Global setting.
Most Base SSRS forms do not have company logos from my recollection, but the few that do (mostly outward facing) I believe, will pull the logo from the Company Maintenance UI.
So far, in Epicor Kinetic, while you can add logos to individual report styles, there isn’t a built-in feature that allows you to set a logo globally for all forms at once through a single Company Global setting.
In my brief exposure adding logos typically requires you to modify each report style individually where you want the logo to appear. In my case, I created a template report which I use as my starting point with all the elements I would like to see and from there, I start editing.
However, you can streamline the process a bit by:
- Modify Report Data Definitions (RDDs): updating the RDD to include a logo might propagate the change across all reports based on that RDD.
- Customization or BPM (Business Process Management): You can create a customization or a BPM that automatically injects your logo into reports during the rendering or printing process. This is the step where you need to have some advanced customization exposure.
Hope this helps.
Hila
I feel that the Logo you can pull from Company Configuration is for the UI and not the SSRS reports, I’ll give it a try my I’m 95% sure will not work as expected, still thanks for the tip.
Slightly different approach, add a us field to the company table, then a BPM when for when you upload the logo, convert the image to base64.
Pretty mush all SSRS reports have a Comp data set here, just ad the UD field to the ds then convert the base64 field to image in the SSRS.
