Global BAQs - warning on later versions
If you use Global BAQ's, you've probably run into times where you make a
change to the query, and it doesn't flow to the other companies that use the
BAQ's. Our way around it had been to delete the BAQ in the other companies
that use the query, then remark it as global - which would copy the
refreshed version down to the other companies.
However, in version 9.05.605, when you delete the BAQ in the related
companies, it deletes the query in the source company. Beware!!
Kevin Simon
