tonygardner
(Tony Gardner)
September 18, 2024, 1:59pm
1
Hello.
I am attempting to retrieve a value from our UD23 table, but the developer who designed it used a GUID in Key4, so I am unable to use GetByID. So, I am now trying to use a ProLoadSearchFilter, but it is not successfully finding the record. Here is the code I have right now:
private decimal GetUD23Num(string colName, int ordNum, int cusNum, string pproID)
bool ud23OK = false;
decimal colValue = 0;
if(colName == "") return colValue;
string ordStr = ordNum.ToString();
string cusStr = cusNum.ToString();
try
adp23 = new UD23Adapter(this.oTrans);
adp23.BOConnect();
int invNum = FetchInvoiceNumFromOrder(ordNum);
string invStr = invNum.ToString();
SearchOptions ud23Opts = new SearchOptions(SearchMode.AutoSearch);
ud23Opts.DataSetMode = DataSetMode.RowsDataSet;
ud23Opts.SelectMode = SelectMode.SingleSelect;
ud23Opts.PreLoadSearchFilter = String.Format("Key1 = '{0}' AND Key2 = '{1}' AND Key3 = '{2}'",ordStr,invStr,cusStr);
adp23.InvokeSearch(ud23Opts);
ud23OK = (adp23.UD23Data.UD23.Rows.Count > 0) ? true:false;
catch (Exception ex) {}
finally
if(ud23OK == true)
colValue = Convert.ToDecimal(adp23.UD23Data.UD23[0][colName]);
adp23.Dispose();
return colValue;
If I use Visual Studio to debug the code, my ud23OK boolean is always returning false. Is it possible I didn’t code the Rows.Count conditional correctly?
kve
(Kevin Veldman)
September 18, 2024, 2:18pm
2
I haven’t worked a ton using the InvokeSearch from an adapter, but looking at some of my code, it’s set up a little different. Give the below a try:
try
adp23.BOConnect();
ud23Opts.NamedSearch.WhereClauses.Add("UD23", String.Format("Key1 = '{0}' AND Key2 = '{1}' AND Key3 = '{2}'",ordStr,invStr,cusStr));
finally
if(ud23OK == true)
adp23.Dispose();
return colValue;
tonygardner
(Tony Gardner)
September 18, 2024, 4:05pm
3
Thanks so much for the good effort, Kevin. If anything, you encouraged me to keep trying other methods. Here’s what I ended up with:
bool recSelected = false;
string whereClause = String.Format("Key1 = '{0}' AND Key2 = '{1}' AND Key3 = '{2}'",ordStr,invStr,cusStr);
DataSet dsUD23 = SearchFunctions.listLookup(this.oTrans, "UD23Adapter", out recSelected, false, whereClause);
if(recSelected)
DataRow adapterRow = dsUD23.Tables[0].Rows[0];
colValue = Convert.ToDecimal(adapterRow[colName]);
return colValue;
Cheers,
Tony G.
