Gene,
The error message was pretty clear (for a change ) -
Instead of:
( "nedEpiCustom2" ) = (args.proposedvalue , "OrderQty') * NetWeight)
Try:
( "nedEpiCustom2" ) = (args.proposedvalue , ("OrderQty") * NetWeight)
I'm assuming you defined NetWeight as a public numeric variable (and given it a value) somewhere else in your Modules' code.
Rob
Sent: Monday, May 18, 2009 11:57:10 AM
Subject: [Vantage] Getting Closer
Thank you Calvin for your help. I am Getting closer. This is the code I have in and the error I am getting. The If statement is line 73. The "nedEpiCustom2" is the name of the box where I want this to calculation to show up. Any idea what else I may need to make it work?
This is my fisrt try at doing any codeing in Vantage. My training for doing this coding hs been going on now since 7:00 a.m. on the 18th of May.
Thank you in advanced for any help anyone can give me.
Gene Mack
Johnson Systems
Private Sub OrderDtl_AfterField Change(ByVal sender As object, ByVal args As DataColumnChangeEve ntArgs) Handles OrderDtl_Column. ColumnChanged
'// ** Argument Properties and Uses **
'// args.Row("[FieldNam e]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Dim edv As EpiDataView = CType(oTrans. EpiDataViews( "OrderDtl" ), EpiDataView)
Select Case args.Column. ColumnName
Case "OrderQty"
IF (args.proposedvalue , "OrderQty") > 0 THEN edv.dataView( edv.Row)( "nedEpiCustom2" ) = (args.proposedvalue , "OrderQty') * NetWeight)
Case Else
End Select
End Sub
Compiling Custom Code ...
----------errors- --------- --
Error: BC30198 - line 73 (288) - ')' expected.
** Compile Failed. **
Instead of:
Try:
Rob
Gene Mack
Johnson Systems
Case "OrderQty"
Case Else
End Select
End Sub
