Thanks Jose, will give it a shot.
To: Vantage <vantage@yahoogroups.com>
Sent: Tuesday, May 21, 2013 8:31 PM
Subject: Re: [Vantage] Re: Get New UD01 Record - Vista 8.03.409
You can use Reflection to get to the Protected Parent View
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
 <http://www.usdoingstuff.com>
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, May 21, 2013 at 5:33 PM, tkoch77 <tkoch77@...> wrote:
> Reposting the parentView question just in case some of you missed it being
> at Insights.
> Thanks!
> -Ted
> --- In vantage@yahoogroups.com, Ted Koch <tkoch77@...> wrote:
> > Almost have this working, the only part that is still not 100% is
> Deleting a record.
> > I am getting a compile error indicating:
> >Â Error: BC30390 - line 208 (426) -
> 'Epicor.Mfg.UI.FrameWork.EpiDataView.parentView' is not accessible in this
> context because it is 'Protected'.
> > Does anyone know the equivalent of EpiDataView.parentView in Vista?
> Looking in the Object Explorer under EpiDataView properties, parentView is
> not there.
> > Thanks again,
> > -Ted
> > From: tkoch77 <tkoch77@...>
> > Sent: Wednesday, May 15, 2013 4:20 PM
> > Subject: [Vantage] Get New UD01 Record - Vista 8.03.409
> > Maybe someone can shed some light on what I am doing wrong. I am trying
> to add UD01 as a child to the customer table and use a datagrid to
> add/delete/edit UD01 records associated to a customer. So far I have
> created a Multi Foreign Key View to bring in UD01 as a view. I am now
> trying to code in creating a new UD01 record. This is what I have on a
> button click to test, but it does nothing. Am I missing something? This is
> converted from what the E9 wizard produces.
> >Â Â Â Â Private Sub GetNewUD01Record()
> >Â Â Â Â 'Dim parentViewRow As DataRow = _edvCustomer.CurrentDataRow
> >Â Â Â Â 'Check for existence of Parent Row.
> >Â Â Â Â 'If (parentViewRow Is Nothing) Then
> >Â Â Â Â If _edvCustomer.Row = -1 Then
> >Â Â Â Â Â Â Exit Sub
> >Â Â Â Â End If
> >Â Â Â Â 'If _ud01Adapter.GetaNewUD01 Then
> >Â Â Â Â Â Â Dim custnum As String =
> _edvCustomer.dataView(_edvCustomer.Row)("CustNum").ToString()
> 'parentViewRow("CustNum").ToString
> >Â Â Â Â Â Â _ud01Adapter.GetaNewUD01()
> >Â Â Â Â Â Â ' Get unique row count id for Key5
> >Â Â Â Â Â Â Dim rowCount As Integer =
> _ud01Adapter.UD01Data.UD01.Rows.Count
> >Â Â Â Â Â Â Dim lineNum As Integer = rowCount
> >Â Â Â Â Â Â Dim goodIndex As Boolean = false
> >Â Â Â Â Â Â While (goodIndex = false)
> >Â Â Â Â Â Â Â Â ' Check to see if index exists
> >Â Â Â Â Â Â Â Â Dim matchingRows() As DataRow =
> _ud01Adapter.UD01Data.UD01.Select("Key5 = '" & lineNum.ToString & "'")
> >Â Â Â Â Â Â Â Â If (matchingRows.Length > 0) Then
> >Â Â Â Â Â Â Â Â Â Â lineNum = (lineNum + 1)
> >Â Â Â Â Â Â Â Â Else
> >Â Â Â Â Â Â Â Â Â Â goodIndex = true
> >Â Â Â Â Â Â Â Â End If
> >Â Â Â Â Â Â End While
> >Â Â Â Â Â Â ' Set initial UD Key values
> >Â Â Â Â Â Â Dim editRow As DataRow =
> _ud01Adapter.UD01Data.UD01.Rows((rowCount - 1))
> >Â Â Â Â Â Â editRow.BeginEdit
> >Â Â Â Â Â Â editRow("Key1") = custnum
> >Â Â Â Â Â Â editRow("Key2") = String.Empty
> >Â Â Â Â Â Â editRow("Key3") = String.Empty
> >Â Â Â Â Â Â editRow("Key4") = String.Empty
> >Â Â Â Â Â Â editRow("Key5") = lineNum.ToString
> >Â Â Â Â Â Â editRow.EndEdit
> >Â Â Â Â Â Â ' Notify that data was updated.
> >Â Â Â Â Â Â _edvUD01.Notify(New EpiNotifyArgs(oTrans, (rowCount - 1),
> _edvUD01.Column))
> >Â Â Â Â 'End If
> >Â Â End Sub
> > Thanks,
> > -Ted
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
>Â
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
