Dear Team,
How to get the current plant id for the company (logged in company) in BPM? in update method.
Dear Team,
I assume you are doing a method directive. In Base Processing, you can use the “Set BPM Data Field” function to set one of the Character fields to current plant and then use it in your BPM.
Once you select the “Set BPM Data Field” make a change to what your target field is and what the source is.
Then for the “specified” expression. Select “Current Plant”. This will bring Plant into your current set of data. You can use that “Character1” field that you have now set in your data set.
