Generate Shop Load Capacity Process
Hello! I was given a list of Resources to add to each applicable Resource Group. When I add a new resource, I’m getting a message that says “Capacity changed, therefore, the ‘Generate Shop Capacity Process’ will need to be run to update ShopLoad records.”
We are not currently utilizing the Shop Load Reports (that is a goal in the near future) and I am not familiar with this area. I think I need to generate this process in order for the Shop Load Reports to be accurate when we eventually use them.
Without anyone in my organization being familiar with this, I wanted to see if any of you can provide any additional information in regards to what this process affects, if it can cause any unexpected results, and if it needs to be run during off hours. From what I have read, this will need to be run regularly when we begin utilizing the Shop Load Report, but I’m not sure if it should be a priority now.Thank you for your time!
