Generate PO Suggestions
I don't know when Non-nettable warehouse bins  were established by Epicor or Vantage, but you may want to look at the bin setup that holds the on-hand balance. Non-nettable bin quantities aren't used in MRP or for suggestions.
In Version 5.2 does anyone know if it is necessary to Generate PO
Suggestions if you are running a full MRP regen?
We have a part that is Active with 0 on hand qty that has not generated any PO suggestions in the last six months.  Does anyone know what settings could be preventing the part from generating a PO suggestion?  Or if this is how the generate PO suggestion process is supposed to work for these types of scenarios?
Good Day CChang:
            Did it previously generate suggestions and stopped?
            Are you running “Gen PO Suggestions” or MRP?
            Is there demand for the part – Sales-Order, JOB-material,  Safety-Stock.
            On the Parts screen:
                        Gen>Plant>detail   is “Generate PO Suggestions” box checked
                        Gen>Part  ( also,Gen>Plant>Detail)    check “Qty Bearing”
            Or         Gen>Plant   “Process MRP”
            Other boxes not checked?
            Are other parts generating PO-Suggestions  ( in 9.05.700C on Time-Phase screen you can uncheck “Suggestions” so they exist but do not show)
        Len
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cchang@...
Sent: Wednesday, January 08, 2014 11:57 AM
Subject: [Vantage] Generate PO Suggestions
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
If no demand it wont give the buyers a suggestion.  It will process the part, but no suggestion.
Miguel A. Santillan
Compass Manufacturing Systems
510-661-6666  Office
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chang, Chia
Sent: Wednesday, January 08, 2014 11:44 AM
Subject: RE: [Vantage] Generate PO Suggestions
Yes, we have all the checked boxes checked in the Parts screen that you suggested below.  We run the generate PO suggestions process.  I am not sure if there was a demand for the part, I would have to check.  So even if there is no demand, if it is an active part with 0 on hand qty, would this still generate a PO suggestion without a demand?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Len Hartka
Sent: Wednesday, January 08, 2014 11:14 AM
To: 'vantage@yahoogroups.com'
Good Day CChang:
        Len
I would think it would.
Logic/Algorithms
The Minimum On-Hand functionality uses this logic to calculate its results.
• If the On-Hand Quantity is < the Minimum On-Hand quantity, then generate one or more suggestions for
this part at this plant.
• If the Re-Order to Max check box is selected, then use the Maximum On-Hand quantity for the demand
quantity. If this quantity is larger than the Maximum Lot Size, then create multiple suggestions until the
Maximum On-Hand quantity is consumed
Do you run a NetCHange or Regen?
Miguel A. Santillan
510-661-6666  Office
Sent: Wednesday, January 08, 2014 12:45 PM
The Part has the Inventory settings set below in the Part screen.  With the settings below, would a PO suggestion be generated because the part has 0 on hand qty?  Or is it because our safety stock is set to 0 which doesn’t generate a PO suggestion demand?  I would expect a demand to be generated based on the Inventory settings below for a PO suggestion.
Min On-Hand: 9
Max On-Hand: 14
Safety Stock: 0
Re-Order to Max: Checked
Min Order Qty: 0
Lead Time: 14
Forecast Time: 0
Generate PO Suggestions: Checked
Quantity Bearing: Checked
Type: Purchase
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Miguel Santillan
Sent: Wednesday, January 08, 2014 2:00 PM
Miguel A. Santillan
510-661-6666  Office
Good Day CChang:
        Len
Good Day Chia:
            With min-on-hand at 9, it should create a suggestion.
            When you run “gen PO Suggestions” you have to check some boxes and add a date. Check how you run it.
            Did it previously create suggestions for this part?
For a test, put the part, and some other part, on a sales order, run gen-po-sug. Did it create a suggestion?
                        If not, change date or check boxes and try again.
        Len
Sent: Wednesday, January 08, 2014 3:45 PM
Min On-Hand: 9
Max On-Hand: 14
Safety Stock: 0
Min Order Qty: 0
Lead Time: 14
Forecast Time: 0
Type: Purchase
Miguel A. Santillan
510-661-6666  Office
Good Day CChang:
        Len
Good Day Chia:
SugPoDtl  has records.
Not in PODtl --- might show in PartDtl, but SugPoDtl is best bet.
In Time-phase screen, do suggestions show for other Part#’s.
What screen are you using to look at suggestions – some screens show only parts for a specific BUYER.
        Len
Sent: Wednesday, January 08, 2014 5:53 PM
No, it has not previously created a suggestion once the on hand qty went down to 0.  Even if it did, I could not find a PO associated to that Part using a BAQ query.  Would PO suggestions show up in the PODtl table?
Sent: Wednesday, January 08, 2014 4:39 PM
Good Day Chia:
        Len
Min On-Hand: 9
Max On-Hand: 14
Safety Stock: 0
Min Order Qty: 0
Lead Time: 14
Forecast Time: 0
Type: Purchase
Miguel A. Santillan
510-661-6666  Office
Good Day CChang:
        Len
Good Day:
            Also, on some screen you have to click on refresh icon at the top of the binocular icons.
            You also need to click on right item in the “tree’ area.
        Len
Sent: Wednesday, January 08, 2014 6:16 PM
Good Day Chia:
        Len
Good Day Chia:
        Len
Min On-Hand: 9
Max On-Hand: 14
Safety Stock: 0
Min Order Qty: 0
Lead Time: 14
Forecast Time: 0
Type: Purchase
Miguel A. Santillan
510-661-6666  Office
Good Day CChang:
        Len
What version are you on?
Are you live?
Sent: Wednesday, January 08, 2014 1:45 PM
Min On-Hand: 9
Max On-Hand: 14
Safety Stock: 0
Min Order Qty: 0
Lead Time: 14
Forecast Time: 0
Type: Purchase
Miguel A. Santillan
510-661-6666  Office
Good Day CChang:
        Len
