Yeah, you're right, I over thought and complicated it likely. The only method the user has to update the CheckBox01 field is by the button I created.
So, I easily created a Pre-Process BPM on Customer.Update and detected if CheckBox is going from false to true. Then actions were to set the values of the row to the same values the .p did, and it all works fine as well as creating change log entries.
I think I had it more complicated because initially I needed to update values and rows of tables not being accessed immediately by the Customer.Update but I've since simplified it to get it accomplished quicker.
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> If the button does an Otrans.Update then I would think you could use the BPM update directive. All you would need is a way in the BPM to distinguish between the button update and a user save. But if the button is updating other fields then you could check one of those fields to see if it was set.
> From: pbparker <scrumbus@...>
> To: vantage@yahoogroups.com
> Sent: Thu, October 22, 2009 10:29:25 AM
> Subject: [Vantage] Re: Generate a change log entry with BAM 4GL executable?
> Â
> Version 9. I have a custom button the user presses that executes code that toggles a custom checkbox on the screen (linked to CheckBox01 in the table) and then does a Otrans.Update.
> That custom checkbox value is monitored by a BAM that's set to execute a .p file on change. In turn that .p 4GL code updates a couple of database values in the Customer table and then sends an email.
> Not sure if I could accomplish this with BPM's being it's a button push.
> --- In vantage@yahoogroups .com, advantage@ . wrote:
> > Are you on 8 or 9 Hmm not sure what your 4gl is doing. But I have set up BPMs where fields get updated and then set bams on those fields and have gotten history. But again its a BPM on a BO that fires?
> > Sent from my Verizon Wireless BlackBerry
> > -----Original Message-----
> > From: "pbparker" <scrumbus@ .>
> > Date: Thu, 22 Oct 2009 13:57:58
> > To: <vantage@yahoogroups .com>
> > Unfortunately I already have BAM's set up on those fields and they're not firing when the 4GL executes against them. So, it would appear that change logs are triggered by the app logic itself and nothing in the database, which would make sense.
> > Guess I'll see if I can find a way to enter a row in the table myself.
> > --- In vantage@yahoogroups .com, advantage@ wrote:
> > > You should be able to set up a seperate bam changE log on those fields to show the history from/to on those fields
> > > From: "pbparker" <scrumbus@>
> > > Date: Wed, 21 Oct 2009 20:36:14
> > > Subject: [Vantage] Generate a change log entry with BAM 4GL executable?
> > > So, I have a BAM executing a 4GL file that updates various Customer field values that the user doesn't have access to. i.e. They click a custom button and it sets the Credit Limit to 0.
> > > However, this method doesn't generate a change log entry with all the data that's changed, it only tracks the event field in the BAM that executed the 4GL.
> > > Is there a way within 4GL to generate or manually insert an entry into the change log for the record. I want to show show what the credit limit was before they kicked off the 4GL.
