FW:Vantage, Deleting Warehouses
Thank you Ronda,
As of 9:08 am EST I have joined the request.
Aaron Hoyt
Hittite Microwave Corporation
Sent: Tuesday, February 10, 2004 8:43 AM
To: Vantage@yahoogroups.com
Subject: [Vantage] FW:Vantage, Deleting Warehouses
Hi to you both, I recently started an enhancement on this subject, see
the
info below Aaron's response. He's right, you have to call in to
"Icky-core" to add your support to the request.
Rhonda
Jasper,
I created an enhancement request back while I was at Design Standards.
The request was to add an "inactive" check box to basically every master
file. It also included making the "inactive" status prevent an item
from being used even if the user directly types in id. I think parts of
this request have been filled, but if you call support, they should
still have it around. If not, if you create one similar to this, I will
be happy to add my name.
Aaron Hoyt
Sent: Tuesday, August 26, 2003 2:07 PM
To: 'Rhonda@...'
Subject: 10136MPS Suggested Enhancement
Rhonda,
I created your blanket enhancement suggestion form for inactive records
to
not be viewed or usable in Vantage.
Thank you,
eMfg Application Support Analyst
e p i c o r Software Corporation
www.epicor.com
800-269-3044 support phone
952-582-5568 support fax
Summary: MISC Enhancement for inactive records to not be viewable or
used
Book: Change Requests
Request no.: 10136MPS
Description / Steps to reproduce:
SUGGESTED ENHANCEMENT:
"Hide" / "De-Activate" records.
The item should not been seen on 'any' screen.
The item should not be available for 'add' functions.
The item should still be valid for qry's, history, etc.
You just won't see them or be able to choose them when adding anything
to
the system.
The Master Table update screens should have a "View" function that would
allow you to see either "Active" --OR-- "Inactive" records.
Also a database purge and summarize ,mark inactive, delete record, zz-do
not
use description, add vbform field to exclude from crystal or
reportbuilder
reports.
Parts, revisions, work centers, warehouses, customers, part classes,
inspectors, purchasing agents, etc...
Resolution:
to
the system.
not
reportbuilder
reports.
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cm54qfg/M=267637.4521690.5694157.1261774/D=eg
roupweb/S=1705007183:HM/EXP=1076507017/A=1945638/R=0/*http:/www.netflix.
com/Default?mqso=60178383&partid=4521690> click here
<http://us.adserver.yahoo.com/l?M=267637.4521690.5694157.1261774/D=egrou
pweb/S=:HM/A=1945638/rand=643180501>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
Hi to you both, I recently started an enhancement on this subject, see the
Rhonda
Jasper,
Aaron Hoyt
To: 'Rhonda@...'
Rhonda,
I created your blanket enhancement suggestion form for inactive records to
Thank you,
www.epicor.com
used
You just won't see them or be able to choose them when adding anything to
the system.
Also a database purge and summarize ,mark inactive, delete record, zz-do not
use description, add vbform field to exclude from crystal or reportbuilder
reports.
Resolution:
the system.
reports.
