aarong
(Aaron Gulley)
1
Any help to help me with this one?
I have this code
// Declare variables
int invNum = this.InvoiceNum;
bool bSmoothed = this.Smoothed;
DateTime? dSmoothDate = this.SmoothDate;
string sLegalNum = this.SmoothLegalNum;
int iPeriod = this.SmoothPeriod;
int iYear = this.SmoothYear;
bool success = false; // Variable to track if the invoice update was successful
string errorMessage = string.Empty; // Variable to store the detailed error message
string grpID = "";
try {
Erp.Tablesets.ARInvoiceTableset invTS = null;
this.CallService<Erp.Contracts.ARInvoiceSvcContract>(bo =>
// Get Invoice By ID
invTS = bo.GetByID(invNum);
// Create buffer
var origRow = invTS.InvcHead.NewRow();
BufferCopy.Copy(invTS.InvcHead[0], origRow);
invTS.InvcHead.Add(origRow);
// Loop data
foreach (var dtRows in invTS.InvcHead)
dtRows.SetUDField("IncomeSmoothed_c", bSmoothed);
dtRows.SetUDField("SmoothPeriod_c", iPeriod);
dtRows.SetUDField("SmoothLegalNum_c", sLegalNum);
dtRows.SetUDField("SmoothYear_c", iYear);
dtRows.SetUDField("SmoothDate_c", dSmoothDate);
dtRows.RowMod = "U";
dtRows.GroupID = grpID;
decimal grpTotalInvAmt = 0;
string opGenMessage = "";
string opLtrCrdMsg = "";
bool lUpdateRan = false;
bool genAmortSched = false;
bo.UpdateMaster(ref invTS, grpID, "InvcHead", false, false, ref genAmortSched, false, invNum, 1, "", false, invTS.InvcHead[0].InvoiceAmt, false, out grpTotalInvAmt, out opGenMessage, out opLtrCrdMsg, out lUpdateRan);
success = true;
this.CallService<Erp.Contracts.ARInvoiceSvcContract>(bo => {
bo.Update(ref invTS);
success = true; // Invoice update was successful
} catch (Exception ex) {
success = false;
errorMessage = ex.InnerException != null ? ex.InnerException.Message : ex.Message;
if (success) {
InfoMsg = "Invoice updated successfully.";
} else {
InfoMsg = "Failed to update the invoice. Error: " + errorMessage;
It’s currently a function the data being passed in.
"InvoiceNum": 200041,
"Smoothed": true,
"SmoothDate": "2023-06-28T10:20:52.599Z",
"SmoothLegalNum": "2024-GJ-00000001",
"SmoothPeriod": 2,
"SmoothYear": 2024,
"grpID": "JY2006"
I keep getting
"InfoMsg": "Failed to update the invoice. Error: Group is required."
I can’t seem to find what it means by Group is required…
I think you can only edit invoices when they exist within a group before they are posted.
aarong
(Aaron Gulley)
3
A uBAQ performs an update perfectly…
aarong
(Aaron Gulley)
4
Change the code a bit…
No luck
string grpID = "";
bool continueProcessingOnError = true;
bool rollbackParentOnChildError = false;
bool errorsOccurred = false;
try {
Erp.Tablesets.UpdExtARInvoiceTableset invTS = null;
//invTS = bo.GetByID(invNum);
// Create buffer
invTS.InvcHead[0].SetUDField("IncomeSmoothed_c", bSmoothed);
invTS.InvcHead[0].SetUDField("SmoothPeriod_c", iPeriod);
invTS.InvcHead[0].SetUDField("SmoothLegalNum_c", sLegalNum);
invTS.InvcHead[0].SetUDField("SmoothYear_c", iYear);
invTS.InvcHead[0].SetUDField("SmoothDate_c", dSmoothDate);
invTS.InvcHead[0].InvoiceNum = invNum;
invTS.InvcHead[0].RowMod = "U";
bo.UpdateExt(ref invTS, continueProcessingOnError, rollbackParentOnChildError, out errorsOccurred);
success = true;
success = false;
if (success) {
} else {
aarong
(Aaron Gulley)
7
Removal of grpID as kevin said this was stupid using his …
klincecum
(Kevin Lincecum)
8
For anyone confused, he was emptying his grpID he passed in as an argument.
Nothing had a grpID
Have you been able to do the update? I’m in a similar situation.
aarong
(Aaron Gulley)
10
I used a uBAQ in the end…
Alvaro-Osorio
(Alvaro Osorio Ibañez)
11
Finally, this is working for me.
// Declaro variables
bool isSent = false;
bool success = false; // Variable que indica si la actualización fue correcta
string errorMessage = string.Empty; // Variable que almacena el mesaje de error
string InfoMsg = string.Empty;
try {
// Obtenigo la factura por el ID
var dsInvoice = bo.GetByID(invNum);
var originalRow = dsInvoice.InvcHead.NewRow();
BufferCopy.Copy(dsInvoice.InvcHead[0], originalRow);
dsInvoice.InvcHead.Add(originalRow);
dsInvoice.InvcHead[0].SetUDField("isSent_c", true);
dsInvoice.InvcHead[0].RowMod = "U";
bo.UpdateMaster(ref dsInvoice, dsInvoice.InvcHead[0].GroupID, "InvcHead", false, false, ref genAmortSched, false, dsInvoice.InvcHead[0].InvoiceNum, 1, "", false, dsInvoice.InvcHead[0].InvoiceAmt, false, out grpTotalInvAmt, out opGenMessage, out opLtrCrdMsg, out lUpdateRan);
success = true;
success = false;
if (success) {
InfoMsg = "Factura actualizada exitosamente.";
} else {
InfoMsg = "Fallo al actualizar la factura. Error: " + errorMessage;
