Thanks to all for the feedback. Our first inventory we did the same
thing with the WIP and Production Detail report. It does take a long
time to count everything with the reports so we were looking to ease the
process. Entering counts into an Access database worked great but I
still had trouble finding the right data in Vantage to duplicate the
entire WIP report so I could automatically produce a variance report. I
finally had to give up (for now) and created a local table to manually
enter the WIP data to get some variances.
Thanks again for you help,
Butch
Sent: Monday, April 04, 2005 8:59 AM
Subject: RE: [Vantage] Full Physical Inventory
Here is how we handle WIP at PI time...
Ensured all jobs that should have been closed were actually closed
(sounds like common sense but after the first time you spend an hour
trying to find a job that was already out the door/on the shelf and
finally find someone to fess up "oh, that job is long gone" you'll
understand).
Any raw material not already consumed by a job is returned back into
inventory.
Any completed pieces received into FGI.
This is usually done in preparation for PI and begins a few days before.
On count day (it should be noted that we do not run production during
PI) we run the WIP report and production detail reports for all open
jobs. All the info. for each job is contained in the PD report so we
utilize this as our "tag". This 'tag' is carried to the floor and wip
is verified. If adjustments are needed we make correcting transactions
at that point. Our marked up report is the source document of these
adjusting transactions and is saved, along with the tags with our PI
package for the auditors.
May not work for everyone but works pretty well for us.
Mike Lowe
Connor Manufacturing Services
Sent: Monday, April 04, 2005 7:28 AM
Cc: 'Milleman, Jim'
Yes - WIP is REAL fun when it comes to a physical inventory!! You know
darn well the system knows how many pieces should be at each operation
of each job at any given time. I wish Epicor could program Vantage such
that WIP could be included in the normal physical inventory process
(i.e. count tags be generated in job number order/by operation). Then,
counts could be entered/posted -- it would take WIP physical inventory
reconcilation/adjusting from nearly 2 days to less than 1 day (like RAW
& FG)!! I believe Epicor's stance is that at a physical inventory, in a
perfect world, you would not have any WIP; HOWEVER... (if your familar
with the commercial, isn't that why CVS Pharmacy exists, because we
don't live near "PERFECT"?!)
Thanks!
Rick Ludwig
Sent: Monday, April 04, 2005 9:06 AM
To audit WIP, which is real fun by the way.
I would print out the work in process report and out each job one by
one.
Go through the materials and labor, this worked for us. But took about
2
days.
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Monday, April 04, 2005 9:56 AM
Subject: [Vantage] Full Physical Inventory
We are in the middle of a full physical inventory and I would like to
see
how other folks are performing the task. The warehouse items are pretty
straight forward because you can use the Count Entry form. We have
found
WIP, Incoming Inspection, DMR and RMA to be a little more challenging
because they are in more of a "queue" than a physical location. I have
created an Access database to enter the count tags and have found most
of
the tables to produce variance reports:
DMRHead -> DMR
RcvDtl, FirstArt, NonConf -> Inspection Processing
RMARcpt -> RMA
The real problem I'm having is coming up with the WIP totals in Vantage.
I've tried reports from the PartWIP, PartTran, JobAsmbl.IssuedQty,
JobMtlIssuedQty tables but none seem to be consistent with what we are
counting. I've compared each of these tables against the Work In
Process
report but none consistently match - of course when I read the help file
that the Work In Process report has "simulated Cost of Sales and WIP
activity ", I'm not sure this is a reliable report for actuals.
Any help would be appreciated,
Butch
have
and
Yahoo! Groups Links
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and
keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the
views of the sender and not necessarily the views of the company. The
email and any files transmitted with it are confidential to the intended
recipient at the e-mail address to which it has been addressed. It may
not be disclosed or used by any other than that addressee, nor may it be
copied in any way. If received in error, please delete and notify the
sender via e-mail or sales@... quoting the name of the sender.
Messages sent via this medium may be subject to delays, non-delivery and
unauthorized alteration. This e-mail has been prepared using information
believed by the author to be reliable and accurate. Unless expressly
stated otherwise, this e-mail does not form part of a legally binding
contract or agreement between recipient and Innovative Office Products,
Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable
precautions to ensure no viruses are present in this email, we cannot
accept responsibility for any loss or damage arising from the use of
this email or attachments. It is, therefore, your responsibility to scan
attachments (if any).
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service < http://docs.yahoo.com/info/terms/> .
_____
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
Butch
understand).
inventory.
Mike Lowe
Cc: 'Milleman, Jim'
Thanks!
Rick Ludwig
one.
2
days.
Frank Zeigafuse
General Manager
see
found
of
DMRHead -> DMR
RMARcpt -> RMA
Process
Butch
have
and
Yahoo! Groups Links
keyboards
Inc.
_____
Yahoo! Groups Links
_____
Yahoo! Groups Links
Yahoo! Groups Links
