Frideas for 28 June 2024
On Friday, it’s EpiUsers Frideas Day! Have you been to the Epicor Ideas Portal recently? If so, are there some ideas you want to encourage other users to vote for? Maybe want to add comments to an existing idea? Remember, Epicor Ideas has a new Landing Zone:
https://epicor.ideas.aha.io/
:face_with_hand_over_mouth:
Created this yesterday. Would love to get this functionality back.
Bring Back Attachment Expose In Tree | Epicor Ideas Portal (aha.io)
Mine is also a Classic functionality missing in Kinetic. Paste Update/Insert into BAQ criteria.
Most of y’all didn’t even know that existed until someone made a thread on it a while back. Now y’all can’t live without it! :rofl:
I submitted the bug was back in E10 days I’ll have to know :stuck_out_tongue: I’ve been using it since it was fixed in 10.2. As cloud SaaS customer now, it’s invaluable as I can’t get into the server to make a SQL query.
In case anybody missed the discussion yesterday, there is a poll going on regarding the part landing page if you click on product polls at the top of the aha page.
I don’t know if nobody cares about this or just haven’t seen the idea, but I still think it would be great functionality to have - I want to be able to set the parameters for my reference query dynamically:
https://epicor.ideas.aha.io/ideas/KIN-I-4528
And this is another one that would be really helpful - there aren’t any filters when you are trying to set up a panel card grid in application studio, so if you have hundreds of columns to sort through its pretty impossible:
https://epicor.ideas.aha.io/ideas/KIN-I-5166
That was fixed year ago, what exactly you cannot insert now?
There is still no paste insert.
In case its not clear:
  1. Create a baq and add a table
  2. In table criteria, add a row and select “in” “specified constant list”
  3. Click on the constant list
  4. In the values list that pops up, you can only paste update, you cannot paste insert.
Classic BAQ Designer yes but not Kinetic BAQ designer has this issue as @aosemwengie1 post shows above.
what about 3 dots menu:
That is live, 2023.2.
And here is pilot, 2024.1.5:
Version?
Wonder where that thread was originated from?? :thinking: :man_shrugging:
Paste Update should still work AFAIK
At least it was when the fix was done
Probably Paste New I have is something very recent
Nope it does not. Nothing happens.
Work around time…
Create a bunch of new “Value List” ROWS first… then paste update.
Just spaz out on the new button and create a bunch of rows… then select the top one and “paste update” into that.
Easy enough for “short” lists… not ideal for “long”… and still needs fixed.
yes the workaround works, but not as well as just . . . going back to classic.
Working in 2023.2 we don’t have a Pilot of 2024.1 yet so I’ll let Alisa take that one.
My Frideas I am pushing today:
Idea # Description Current votes
KIN-I-5203 MRP Logs should be stored in the database 39
KIN-I-5199 Improved displays in MRP Pegging 2
KIN-I-5163 Explorer View for Multi-Level Pegging Display 9
KIN-I-5160 Run PO Suggestions at the same time as Net Change 2
(I guess that is enough for today
