Found issues in 2023.1 thus far
Testing the PILOT 2023.1 have found these issues and submitted tickets. Probably already identified by support but thought I would share.
  1. User Codes that existed in previous version did NOT transfer after 2023.1 needing to be re-created. This caused the AppStudio Customization to fail as well.
  2. Part Manufacturing Comments & Purchasing Comments which were under “Reporting” in NAV Tree (very poor choice to have them) also have issue. They do not show up under that Reporting Card now, and I cannot find them if they were moved to another Card. Have not tested to see if they still pull into a PO or JOB when pulling parts in, but that is what they are there for.
I will update when Support responds, and anything else I find, lol
Thanks!
Mine are all there.
Working with support on item 1. and should have come across.
Item 2, they moved Mfg and Purch comments to main screen in Part Entry, you have to click on “Full Screen” to see them, as they are off screen by default and no longer on the “Reporting” card in Nav Tree.
George
