I found that if you use a Crystal Parameter to prompt the user for anything, then you have to preview the report first or it errors out.
Although I will assume you NOT prompting the user, so my next guess would be multiple data sources. i.e. the xml source got set to two different sources. (I think someone else already suggested this and I would agree with them).
Good luck, (printer drivers my bu?)
DaveO
DaveO
--- In vantage@yahoogroups.com, "Virginia Joseph" <vjoseph@...> wrote:
> Version 8.03.408
> --- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@> wrote:
> > What version of Vantage are you using?
> > -----Original Message-----
> > From: vantage@yahoogroups.com on behalf of Mike Tonoyan
> > Sent: Mon 5/23/2011 6:48 PM
> > Subject: RE: [Vantage] Forms don't print unless Previewed
> > We are having the same issue with custom Crystal reports. No resolution
> > so far. Epicor tech support says it's the printer driver, but several
> > users print the same report to different printers all the time, so it
> > cannot be the driver. The out of the box reports print without any
> > problems using the same printer drivers.
> > Mike Tonoyan / Natel Engr.
> > mtonoyan@
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of Virginia Joseph
> > Sent: Monday, May 23, 2011 3:29 PM
> > Subject: [Vantage] Forms don't print unless Previewed
> > Hello: We are experiencing problems where the job traveler and sales
> > order acknowledgement forms won't print unless they are print previewed
> > first and then sent to the printer. They were printing fine before and
> > it started last week for apparently no reason.
> > Thoughts?
> > Thanks,
> > Virginia Joseph
> > Deep Hole Specialists, LLC
> > vjoseph@ <mailto:vjoseph%40deephole.com>
> > ______________________________________________________________________
> > Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
