For all of you that are confused about formatting code blocks and other types of markup that can be done on this forum, please look at this link and walk through the tutorial. It does a really nice job of introducing you to how you can format your posts. I know I am a bit OCD about this stuff, but it really does make everything easier to read.
Also you can do Tables in E10Help
| Tables | Are | Cool |
| col 1 is | left-aligned | $1600 |
| col 2 is | centered | $12 |
| col 3 is | right-aligned | $1 |
Bookmarking that one! Nice
More examples here too.
In addition to âcodeâ, use the 3 graves with type text when pasting the very long details from an error. Like the following
(closing 3 graves not shown)
becomes:
Message: --------compile errors------------
Warning: BC40056 - line 9 (9) - Namespace or type specified in the Imports âEpicor.Mfg.UI.FrameWorkâ doesnât contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesnât use any aliases.
Warning: BC40056 - line 10 (10) - Namespace or type specified in the Imports âEpicor.Mfg.UI.ExtendedPropsâ doesnât contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesnât use any aliases.
Warning: BC40056 - line 11 (11) - Namespace or type specified in the Imports âEpicor.Mfg.UI.FormFunctionsâ doesnât contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesnât use any aliases.
Warning: BC40056 - line 12 (12) - Namespace or type specified in the Imports âEpicor.Mfg.UI.Customizationâ doesnât contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesnât use any aliases.
Warning: BC42024 - line 162 (1149) - Unused local variable: âdsPORelSearchâ.
Warning: BC42024 - line 163 (1150) - Unused local variable: âdtPORelSearchâ.
Warning: BC42024 - line 181 (1168) - Unused local variable: âdsPartTranâ.
Warning: BC42024 - line 182 (1169) - Unused local variable: âdtPartTranâ.
Error: BC30002 - line 190 (1177) - Type âEpiRowChangedArgsâ is not defined.
Warning: BC42024 - line 209 (1196) - Unused local variable: âdsLaborDtlSearchâ.
Warning: BC42024 - line 210 (1197) - Unused local variable: âdtLaborDtlâ.
Warning: BC42024 - line 228 (1215) - Unused local variable: âdsPartTranâ.
Warning: BC42024 - line 229 (1216) - Unused local variable: âdtPartTranâ.
Error: BC30002 - line 238 (1225) - Type âEpiRowChangedArgsâ is not defined.
Warning: BC42024 - line 257 (1244) - Unused local variable: âdsCustShipâ.
Warning: BC42024 - line 258 (1245) - Unused local variable: âdtShipDtlâ.
Error: BC30002 - line 280 (1267) - Type âEpiDataViewâ is not defined.
Error: BC30451 - line 322 (1309) - ânedEpiCustom65_3a5c34cb_4be6_4d34_85cc_33819b6dbbf9â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 323 (1310) - ânedEpiCustom68_977fed6d_87db_417a_ad12_bb4b2f472417â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 324 (1311) - ânedEpiCustom71_568fa7da_cfc4_4821_8d88_0d2eec64725dâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 325 (1312) - ânedEpiCustom74_0f329e6b_3e5f_4326_8e53_60041f872ea4â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 326 (1313) - ânedEpiCustom125_26b4f7b6_540c_4644_aee6_61024032ef2aâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 327 (1314) - ânedEpiCustom126_0bfcf47c_3b6a_449b_a225_f9113d2d0398â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 328 (1315) - ânedEpiCustom127_f41ab1cf_b2f6_48a5_b727_ae17968b4bcaâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 329 (1316) - ânedEpiCustom128_a1baa95b_f23b_4af1_a629_665124ac14a2â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 330 (1317) - ânedEpiCustom129_7eb28842_eb9c_4455_b7c0_329e7a601afaâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 331 (1318) - ânedEpiCustom130_ef873947_0156_40bd_9c0f_1b09a90b7201â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 332 (1319) - ânedEpiCustom159_dfba5a0a_6822_4455_b1f3_55c43ddf7b91â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 333 (1320) - ânedEpiCustom164_878be376_d1a6_4d59_b2ad_0d8bb6914d73â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 334 (1321) - ânedEpiCustom160_563d956d_69e6_40aa_b964_350f361a6990â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 335 (1322) - ânedEpiCustom165_d318dce9_7130_48bb_8171_73fed1007bbfâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 336 (1323) - ânedEpiCustom161_c2f39374_1b55_448d_aa79_aa50eee48854â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 337 (1324) - ânedEpiCustom166_cf67ad79_dfe6_4d74_9c80_b3cd49c9824câ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 338 (1325) - ânedEpiCustom162_a8ce7d42_39f9_4760_8965_bfd2dd2fd3caâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 339 (1326) - ânedEpiCustom167_f171b9b7_fe37_4131_968c_97eec81a88c6â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 340 (1327) - ânedEpiCustom163_2c6f1a9d_e991_4494_b883_ebdc573bc5b6â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 341 (1328) - ânedEpiCustom168_d376e6d3_b7a9_4d4a_b18e_10f96f35d893â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 342 (1329) - ânedEpiCustom169_8753cd9b_22ff_4b1c_9368_cf4adced78c2â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 343 (1330) - ânedEpiCustom170_1b50e62b_9f51_46f0_9789_faece35fe7a1â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 344 (1331) - ânedEpiCustom171_920dc120_629f_4722_be11_6a9dad9cc230â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 345 (1332) - ânedEpiCustom172_d9c8567d_ef87_415d_a650_30496069e54câ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 346 (1333) - ânedEpiCustom173_dcd6d06a_2ada_49b0_8549_cda469eaf9f2â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 347 (1334) - ânedEpiCustom174_ba1758c7_244f_4408_ab01_39f6d32ad79bâ is not declared. It may be inaccessible due to its protection level.
Error: BC30002 - line 352 (1339) - Type âEpiRowChangedArgsâ is not defined.
Error: BC30002 - line 362 (1349) - Type âEpiDataViewâ is not defined.
Error: BC30451 - line 403 (1390) - ânedEpiCustom47_5d6f0cb4_a370_4cdd_8873_3e4a149ab180â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 404 (1391) - ânedEpiCustom50_f3b67cb6_4e55_435f_8e28_46d8ad506797â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 405 (1392) - ânedEpiCustom53_f73b27c9_56c0_4b2f_894e_a392039cde0dâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 406 (1393) - ânedEpiCustom56_8bbc39fc_c93a_42fe_8a88_7558cdedba40â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 407 (1394) - ânedEpiCustom57_6d9b622c_f737_4184_8945_d4ae33c9e582â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 408 (1395) - ânedEpiCustom58_691e030d_f950_4c42_b8bc_58860be9dd22â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 409 (1396) - ânedEpiCustom59_83067e04_9342_4264_bb53_10d32faa7b6câ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 410 (1397) - ânedEpiCustom60_ce28a37d_e7ce_4a2d_b81e_937aba1cc478â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 411 (1398) - ânedEpiCustom61_e1e9768e_45e7_4433_bd0d_ae6c4513d3c3â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 412 (1399) - ânedEpiCustom62_a46e6826_3f46_49a3_b446_ba5786bb3d43â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 413 (1400) - ânedEpiCustom175_316fe77b_5446_4414_9c3b_8e89cee53286â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 414 (1401) - ânedEpiCustom34_f07e7b08_71cd_47a2_a7b9_62c1cf254e5bâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 415 (1402) - ânedEpiCustom176_d4cb6b03_08f8_44fe_88db_53f4e50042b1â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 416 (1403) - ânedEpiCustom35_d1a539dd_eb1d_48a0_962a_2ac221b3fc2eâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 417 (1404) - ânedEpiCustom31_ddc864b4_f37f_43c7_b4ae_e2811d1d50acâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 418 (1405) - ânedEpiCustom36_811f97dd_3a7a_477b_8126_4427f889fdd5â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 419 (1406) - ânedEpiCustom32_952d98dd_a57f_46f3_8848_37007ce9c11eâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 420 (1407) - ânedEpiCustom37_b1cb68ac_092f_429e_bf2d_fb2e1b9b4543â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 421 (1408) - ânedEpiCustom33_60733d27_a78e_4e39_8682_883a8d4b117fâ is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 422 (1409) - ânedEpiCustom38_047b1d4d_714b_44c5_89f7_b39f55494e29â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 423 (1410) - ânedEpiCustom177_4204d219_708e_4ea6_a12e_23f4136466c5â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 424 (1411) - ânedEpiCustom178_f776bc2a_1325_4965_a736_34b4a80442f0â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 425 (1412) - ânedEpiCustom179_eb651318_cc90_4090_a4e1_884923a35943â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 426 (1413) - ânedEpiCustom180_4bebcdb1_f711_4c50_bd57_be3fcd56daa8â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 427 (1414) - ânedEpiCustom43_25c86de0_72b9_446c_864f_8089668e1814â is not declared. It may be inaccessible due to its protection level.
Error: BC30451 - line 428 (1415) - ânedEpiCustom44_42ab14e4_7e04_4873_943a_b352f4a78cf9â is not declared. It may be inaccessible due to its protection level.
Error: BC30002 - line 431 (1418) - Type âEpiRowChangedArgsâ is not defined.
** Compile Failed. **
Program: Ice.Lib.EpiClientLib.dll
Method: CompileCustomScript
It makes the error details shorter (an embedded scrollable window), and wonât wrap the detail lines, making it easier to read.
Hey Guys, also check out the summarize feature. This is especially handy when posted a long error detail or trace or something. Details that need to be there, but can hinder the flow of the conversation.
It works like this
first, paste in your text, then highlight it. Click the gear icon, and choose hide details.
After you do that, you will see your text bracketed by this code. You can change the âsummaryâ text to whatever you think would be helpful
Then when you post, this is what it will look like. So if you have a ton of text, it really condenses the flow so you can keep the conversation flowing. This really helps when you are trying to return back the earlier in the conversation to re-read some details.
