I have this piece of code going into the form customization script for part maintenance. It should validate a secondary part number field, and insert the part description into a secondary description field.
It’s all compiling okay, but it just doesn’t do anything. The text is pasted in below. Note the messageboxes don’t fire.
Also tried: private void txtServicePartUsePart_Leave(object sender, System.EventArgs args) – no difference. No validation, no part description.
I just can’t see it. Any observation?
Joe
private void txtServicePartUsePart_Validating(object sender, CancelEventArgs args)
MessageBox.Show("0");
EpiDataView edv = ((EpiDataView)(oTrans.EpiDataViews["Part"]));
bool recSelected = false;
string whereClause = "PartNum = '" + txtServicePartUsePart.Text + "'";
DataSet dsPart = Ice.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "PartAdapter", out recSelected, false, whereClause);
if (recSelected)
MessageBox.Show("a");
edv.dataView[edv.Row]["ServicePartUsePart_c"] = dsPart.Tables[0].Rows[0]["PartNum"];
edv.dataView[edv.Row]["UserChar4"] = dsPart.Tables[0].Rows[0]["PartDescription"];
edv.Notify( new EpiNotifyArgs(oTrans, edv.Row, edv.Column) );
else if (txtServicePartUsePart.Text == "")
MessageBox.Show("b");
edv.dataView[edv.Row]["ServicePartUsePart_c"] = "";
edv.dataView[edv.Row]["UserChar4"] = ""; // ----------------- this is line 81 ----------------
else
MessageBox.Show("c");
MessageBox.Show("'" + txtServicePartUsePart.Text + "'" + " is not a valid part number.");
txtServicePartUsePart.Focus();
I am not familiar with that event - is it on a specific control like a textbox? And not even one message box appears?
So you say that even the Leave event doesn’t fire? I frequently use the Enter and Leave events of controls so that shouldn’t be an issue (unless it’s a version specific issue)
Do you see the event wired up in form load and destroy?
Are there any other things happening in your customization that allows you to verify the customization is actually being loaded?
I never made that validation method work. I switched to one of the form
wizards - BeforeFieldChange. It works okay, but if I, say, try to stuff the
part number I read in from the data set into the secondary part number
field, it trips the change event again and starts an infinite loop. So I
just don’t do that part.
I would like to have that functionality for when the user keys in a part
number in a different upper/lower case than is on the part table. Ah, well.
You need to either paste the event handler lines in your script header or use the event wizard to put it there automatically for the validating event. It should trigger as soon as you tab out or click off the field.
Ross
public static void InitializeCustomCode()
Script.txtServicePartUsePart.Validating += new System.ComponentModel.CancelEventHandler(Script.txtServicePartUsePart_Validating);
public static void DestroyCustomCode()
Script.txtServicePartUsePart.Validating -= new System.ComponentModel.CancelEventHandler(Script.txtServicePartUsePart_Validating);
// Begin Custom Code Disposal
// End Custom Code Disposal
If you decided to stay with the BeforeFieldChange - you can differentiate which field fired the event and handle accordingly. This would stop your loop.
