Foreign Key Value on User Defined Tables
You need to go to Extended Properties Maintenanec and select the UD20 table and set the Like value of ShortChar01 to be Part.PartNum.
The close / re-launch your epicor and it should give you the drop down
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Thu, Apr 9, 2015 at 11:43 AM, Charles Carden shadowcar1449@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>Running Epicor 9.702a.  Am trying to set up a Foreign Key Value using <br>
UD20 table into Part table with ShortChar 01 as the key. When I add the
FKV I do not get anything in the Column Name field to select.
Consequently I am unable to add the FKV. Is there something I am doing
wrong or is there a problem with the UD tables and a FKV? I can add a
FKV using non-UD tables without any problem.
Thanks in advance
</div>
<div style="color:#fff;min-height:0;"></div>
Thanks in advance
