FKV WIth UD Tables
In the available Views there is no UD Tables showing.
Scott
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Sent: Thursday, September 02, 2010 4:41 PM
Subject: Re: [Vantage] FKV WIth UD Tables
Scott -
Yes I was able to get this to work. Here's some instructions:
In customization mode, under data tools, you will first go to the "Custom Column Like" Tab.
Then in the available views choose your UD Table. On the left side under available Columns choose the field you want to link to the other table. You will then click the Edit like property and put in the Data Type(e.g. System.String) then the like column Value for the key to the other table(e.g. JobHead.JobNum) You will then click "Apply Like Property" Click ok then save and close.
Load the customization and go back into the data tools to now create the FKV. Give the view a name and then select your UDTable as the parent.
When you go to choose the column name you should now see your vb fields in there to select.
Sent: Thu, September 2, 2010 3:37:37 PM
Subject: RE: [Vantage] FKV WIth UD Tables
Dustin,
Did you ever get this to work. I would be interested.
Scott
melissa hietala
Sent: Monday, August 09, 2010 2:52 PM
Subject: [Vantage] FKV WIth UD Tables
I created a custom screen in Vantage utilizing the "UD02" table. Is there a
way I can create a foreign key view from the "UD02" table to the Employee
table so that I can display employee information on this particular screen?
Dustin Biniek
I created a custom screen in Vantage utilizing the "UD02" table. Is there a way
I can create a foreign key view from the "UD02" table to the Employee table so
Â
Dustin Biniek
For version 8.03.4xx the simple answer is no. In truth, it can be done, but it
is messy and requires an edit on each workstation. Epicor has some instructions
on how to do it.
When I need to display UD information in a particular screen, I resort to
calling BO objects through the customization and assigning the resulting dataset
as the data source to an ultra grid view. Complicated, but works without having
to modify each workstation.
Sent: Mon, August 9, 2010 3:51:50 PM
Â
Â
Dustin Biniek
I have to respectfully disagree, unless I am missing something. I have FKV to customer, vendor, and a bunch of other tables using UDTables & Forms.
You first need to create a new "Custom Column Like" & then create the Foreign Key View. This is all done using the data tools that you normally use in customization mode.
> on how to do it.
> From: melissa hietala <kevmel822@...>
> ÂÂ
> Thanks,
> ÂÂ
> Dustin Biniek
Â
I've never utilized the "Custom Column Like" feature before. Could you give me
a quick description on how to use this?
Â
Â
Sent: Mon, August 9, 2010 4:06:08 PM
Subject: [Vantage] Re: FKV WIth UD Tables
customization mode.
>it
>instructions
> on how to do it.
>dataset
>having
> ÂÂ
>way
> Thanks,
> ÂÂ
> Dustin Biniek
I would be interested also. Epicor told me you couldn't create a custom column
Like for a UD table using the data tools in 8.03.4xx. It had to do with the
fact that UD tables have five key columns instead of one.
Sent: Mon, August 9, 2010 7:43:10 PM
Subject: Re: [Vantage] Re: FKV WIth UD Tables
Â
Â
Â
Â
customization mode.
>it
>instructions
> on how to do it.
>dataset
>having
> ÂÂ
>way
> Thanks,
> ÂÂ
> Dustin Biniek
In the data tools you will first go to the "Custom Column Like" Tab.
create the FKV. Give the view a name and then select your UDTable as the parent. When you go to choose the column name you should now see your vb fields in there to select.
If I get some time later this week I can do some screenshots with step by step & upload.
> ÂÂ
> ÂÂ
> ÂÂ
> Thanks
> ÂÂ
> From: mmcwilliams22 <mmcwilliams22@...>
> customization mode.
> >it
> >instructions
> > on how to do it.
> >dataset
> >having
> > From: melissa hietala <kevmel822@>
> > ÂÂÂ
> >way
> > Thanks,
> > ÂÂÂ
> > Dustin Biniek
The problem I have is that the UD Table is not listed in "Custom Column Like"
tab. I can add it by editing the ContextMenu.XML file, but this is client
specific.
Â
After reading your response, I think I see where the issue lies. I need to ad a
UD table as a FKV to lets say the Order Entry Form. It looks like you are
talking about adding something like JobHead to a UD form. So back to the
original question (which I misread), yes you are right, it can be done.Â
Unfortunately, I usually need to do the reverse.
Sent: Tue, August 10, 2010 9:14:22 AM
Â
to select.
upload.
>column
> ÂÂ
> ÂÂ
>me
> ÂÂ
> Thanks
> ÂÂ
> customization mode.
>but
> >it
> >instructions
> > on how to do it.
> >dataset
> >having
> > ÂÂÂ
>there a
> >way
>table so
> > Thanks,
> > ÂÂÂ
> > Dustin Biniek
Yes I have the same issue in reverse & will use the adapter.
> specific.
> ÂÂ
> original question (which I misread), yes you are right, it can be done.ÂÂ
> ÂÂ
> to select.
> upload.
> >column
> > ÂÂÂ
> > ÂÂÂ
> >me
> > ÂÂÂ
> > Thanks
> > ÂÂÂ
> > From: mmcwilliams22 <mmcwilliams22@>
> > customization mode.
> >but
> > >it
> > >instructions
> > > on how to do it.
> > >dataset
> > >having
> > > ÂÂÂÂ
> >there a
> > >way
> >table so
> > > Thanks,
> > > ÂÂÂÂ
> > > Dustin Biniek
Dustin,
Scott
melissa hietala
Â
Dustin Biniek
Scott -
Like" Tab.
to select.
Â
Dustin,
Scott
melissa hietala
Â
Dustin Biniek
