FKV on Custom Form not showing UD Field
I have customised the Kanban Receipts form to include an FKV to the Part Revision table. We want to show the Revision Short Description and a UD field we are taking over from Vantage. I know I have set the FKV up correctly as the revision description is showing but the UD field is blank (screenshots below). Is it because it’s a UD field and if so, what’s the best way to bring that data in? Thanks.
Can you post an image of your FKV? I would expect to see a PartView and the PartRevDesc should be a sub-view.
Yes, that’s how I did it, and the link seems to be fine as the Revision Short Description is showing correctly.
The Sub Table View looks odd. Here is how I would build it:
Sorry, but apart from the View Name I can’t see a difference?
You likely are right, but the names confused my eyes. :slight_smile:
This should work fine for the UD field, so unless your fields don’t actually match, I would Report this to support.
Thanks for looking it over. I’ll raise a call :blush:
Regards
Tracy Smith
I just wanted to confirm the solution for this was the size of the box displaying the data. :woman_facepalming:
