Find and Replace BPM
ok, no worries, thank you.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> No offense man, but the info I gave you is the best i've got, lets try again
> If you have the string
> " *A person's a person, no matter how small.* "
> And you run
> Replace ("*A person's a person, no matter how small.* "," * person's a
> person* ","elephant is loopy")
> You'll get A elephant is loopy, no matter how small...
> you can put it in a loop as such
> FOR EACH Part:
> Assign Part.PartDesc = REPLACE(Part.PartDesc, "STUFF I DONT LIKE","THING I
> LOVE")
> END.
> Hope this helps!
> *Jose C Gomez*
> *Software Engineer*
> *checkout my new blog <http://www.usdoingstuff.com> *
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Fri, Feb 3, 2012 at 8:47 AM, michael.hutcheson@... <
> michael.hutcheson@...> wrote:
> > We have part descriptions that are like the following:
> > SWLR blah blah blah
> > blah blah SWLR blah blah
> > blah blah SWLR
> > Would this still ensure I keep all the blah blah's?
> > How do I incorporate this into my code?
> > Thanks again.
> > --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > > Naw captain.
> > > REPLACE ( source-string , from-string , to-string ).
> > > All three of those arguments need to be replaced with the actual data.
> > > Stick it in the middle of your loop and you should be ok.
> > > On Fri, Feb 3, 2012 at 8:34 AM, michael.hutcheson@ <
> > > michael.hutcheson@> wrote:
> > > > Thanks for this.
> > > > Do I litterally just use the words source-string? I was planning on
> > > > running this on-mass so the descriptions will be all be slightly
> > different.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > On Fri, Feb 3, 2012 at 8:16 AM, michael.hutcheson@ <
> > > > > > Hey folks,
> > > > > > Is it possible to perform a find and replace BPM? What I want to
> > > > achive is
> > > > > > only replace specific words in the parts descriptions, and leave
> > the
> > > > rest
> > > > > > of the description intact.
> > > > > > I was thinking of using a BPM with 4GL code:
> > > > > > for each Part where ( Part.PartDescription MATCHES
> > '*SWLR*')no-lock:
> > > > > > Run lib\UpdateTableBuffer.p(input BUFFER Part:HANDLE,
> > > > > > 'PartDescription','Swivel- Long radius').
> > > > > > However, this will overright the entire description, I only want to
> > > > > > replace 'SWLR' with 'Swivel- Long radius' - any ideas?
> > > > > > Regards,
> > > > > > Michael
> > > > > [Non-text portions of this message have been removed]
> > > *John Driggers*
> > > *High End Dev, System Design, Profit Drinking
> > > *:: 904.962.2887*
> > > *:: waffqle@*
> > > *:: NO FAXES*
Hey folks,
Is it possible to perform a find and replace BPM? What I want to achive is only replace specific words in the parts descriptions, and leave the rest of the description intact.
for each Part where ( Part.PartDescription MATCHES '*SWLR*')no-lock:
Run lib\UpdateTableBuffer.p(input BUFFER Part:HANDLE, 'PartDescription','Swivel- Long radius').
However, this will overright the entire description, I only want to replace 'SWLR' with 'Swivel- Long radius' - any ideas?
Regards,
Michael
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Fri, Feb 3, 2012 at 8:16 AM, michael.hutcheson@... <
> Hey folks,
> Regards,
> Michael
Thanks for this.
Do I litterally just use the words source-string? I was planning on running this on-mass so the descriptions will be all be slightly different.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hey folks,
> > Regards,
> > Michael
Naw captain.
On Fri, Feb 3, 2012 at 8:34 AM, michael.hutcheson@... <
> Thanks for this.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hey folks,
> achive is
> rest
> > > Regards,
> > > Michael
*John Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
source-string
Specifies the base string to make replacements in. The source-string
parameter can be
any expression that evaluates to a string or a LONGCHAR. The REPLACE
function does
not change the value of source-string itself; the function returns the
string with
replacements.
from-string
Specifies the substring to replace. The from-string parameter can be any
expression that
evaluates to a string or a LONGCHAR. Each occurrence of from-string within
source-string is replaced.
to-string
Specifies the replacement substring. The to-string parameter can be any
expression that
evaluates to a string or a LONGCHAR. Each occurrence of from-string in
source-string is replaced by to-string.
The following example uses the REPLACE function to replace the string
�user� with an actual
user ID, if available:
DEFINE VARIABLE greeting AS CHARACTER NO-UNDO FORMAT "x(40)"
INITIAL "Starting user�s session . . . ".
IF USERID("DICTDB") < > "" THEN
greeting = REPLACE(greeting, "user", USERID("DICTDB")).
DISPLAY greeting WITH NO-LABELS.
The REPLACE function replaces all occurrences of from-string within
source-string.
After replacing a substring, the REPLACE function resumes searching the
string after the
inserted text. Thus, the inserted text is not recursively searched (in
whole or in part) for
from-string.
The search for occurrences of from-string within source-string is not case
sensitive,
unless one of the three values used in the function (source-string,
to-string, or
from-string) is a case-sensitive field or variable.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Fri, Feb 3, 2012 at 8:39 AM, John Driggers <waffqle@...> wrote:
> Naw captain.
> > Thanks for this.
> different.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Hey folks,
> > achive is
> > rest
> > > > Regards,
> > > > Michael
> *John Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
SWLR blah blah blah
blah blah SWLR
Thanks again.
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> Naw captain.
> > Thanks for this.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > Hey folks,
> > achive is
> > rest
> > > > Regards,
> > > > Michael
> *John Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
And you run
FOR EACH Part:
LOVE")
END.
Hope this helps!
*Jose C Gomez*
*Software Engineer*
E: jose@...
> SWLR blah blah blah
> blah blah SWLR
> Thanks again.
> > Naw captain.
> > > Thanks for this.
> different.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > Hey folks,
> > > achive is
> the
> > > rest
> '*SWLR*')no-lock:
> > > > > Regards,
> > > > > Michael
> > *John Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@...*
> > *:: NO FAXES*
