You are AWSOME!!!! I got it! Thank you!
Patricia
Sent: Monday, November 03, 2014 3:03 PM
Subject: [Vantage] RE: Field added to RMA Form does not display
Patricia,
Try this:
OrderHed to OrderDtl you just need Company and OrderNum.
RMADtl to OrderHed you cust need Company and OrderNum.
I use the Data Dictionary Viewer and look at the indexes.
Your joins should follow one of the indexes for performance and linking as a guideline.
But you don’t have to follow this exactly
Also if your data is in the xml but doesn’t display in crystal, make sure your using the field from say OrderDtl and not the same field from say PartTran, I know it should obvious but it is Monday.
Patrick Winter
My relationships in Epicor are:
OrderHed to OrderDtl (fields are Company, OrderNum and CustNum)
RMADtl to OrderHed (fields are OrderNum and CustNum)
Sent: Monday, November 03, 2014 14:43
Patrick,
That’s the problem. I first need to make sure I have my relationships right in Epicor don’t I? I’m not sure I do. If I do then I can go back to Crystal and hopefully replicate it there. I as far as I know they should also be left outers in Crystal.
Patricia
Sent: Monday, November 03, 2014 2:15 PM
Check under crystal / Database Expert / Links. Is everything joined properly.
Arrow from Parent to Child Tables in Crystal, Epicor BAQs Arrows are from Child to Parent.
Patrick
Sent: Monday, November 03, 2014 13:58
Subject: [Vantage] Field added to RMA Form does not display
All,
I’m hoping someone can tell me where I’m going wrong. This is driving me nuts. I’m running 905.702a, Crystal Reports, and SQL.
I have modified my RMA Form to add the OrderHed and OrderDtl tables. I don’t have an issue with the OrderHed table, the data shows up in the form and all is well. The problem is with the OrderDtl table. I can see the data in the xml and I can see it when I browse data in Crystal. The problem is that the data does not display on the report. I can drag and drop the field I need onto the form but it never displays.
RMAHead to RMADtl (field is RMANum)
Can someone please help? I always have problems with this.
Patricia Hall
Systems Analyst
T: 256.978.6294
E: phall@...
This email and any attached files are confidential and intended solely for the intended recipient(s). If you are not the named recipient you should not read, distribute, copy or alter this email. Any views or opinions expressed in this email are those of the author and do not represent those of the Specialty Screw Corporation company. Warning: Although precautions have been taken to make sure no viruses are present in this email, the company cannot accept responsibility for any loss or damage that arise from the use of this email or attachments.
