Faxing from Vantage
> Sorry but we never pursued the faxing side. Opted for more use of emailed
> PDF versions.
If you have a network-based fax machine, as many are these days, we Print
Preview our PDF at the desktop and then File | Print to the fax machine.
It is not as nice as an automatic print but we found that we want to check a
document for correctness before we sent it anyway.
Mark W.
Our purchasing manager has a Hewlett Packard 3150
Fax/Copier/Scanner/Printer on his workstation (and a dedicated
phone line for the fax).
Today, he tried to 'print' a purchase order, out of Vantage, directly
to the fax machine. On the 'other end' (he tested it by sending the
PO to another fax number we have here), the resulting image has
grayed boxes, and the text is out of alignment. We're using the
Crystal PO report/form.
Now, I realize that the 'print driver' in the fax side of the HP
machine is not intrepting this correctly, but when he 'prints' a hard
copy of the PO to the printer side of the same HP machine, it
prints out fine. I don't think I can 'adjust' the fax driver, and I don't
really want to mess with the PO report in Crystal (especially since
it prints a hardcopy fine).
We're trying to eliminate the print-to-paper-then-FAX shuffle. Any
ideas?
Thanks!
Malcolm Spann
MIS
Malmberg Engineering
(925) 606-6500 x19
(925) 606-6505 FAX
Malcolm@...
The only thing I can think of is to go to HP's site and make sure you have
all the latest drivers installed for the unit.
Sent: Wednesday, October 31, 2001 12:34 PM
Subject: [Vantage] Faxing from Vantage
ideas?
Thanks!
Malcolm Spann
MIS
(925) 606-6500 x19
(925) 606-6505 FAX
Malcolm@...
For images, we like Acrobat. Works great with Vantage, the reader is free
and widely used, the images are great, and we can keep copy of the document
if we want. If you have a full-version of Acrobat (couple hundred bucks) on
the workstation, you just print to the Acrobat Distiller, from there send-to
email recipient and Outlook picks it up and treats it as a normal new
outgoing email - fill in the "To" & "Subject" blanks and send it. Fast,
simple and makes you look good to the users when you show it to them. And
you can use all the other features that come with Acrobat.
Gary Polvinale
Denton ATD
Sent: Wednesday, October 31, 2001 1:34 PM
ideas?
Thanks!
Malcolm Spann
MIS
(925) 606-6500 x19
(925) 606-6505 FAX
Malcolm@...
Try changing your Fax Setting from Normal to Fine or Photo mode. It
will be slower to transmit but, I may get it there in one piece.
Dave
directly
the
hard
I don't
> ideas?
> Thanks!
> Malcolm Spann
> MIS
> (925) 606-6500 x19
> (925) 606-6505 FAX
> Malcolm@M...
We Print PO's through Crystal and use Lightning Fax. Fax numbers are stored
in the Outlook Contact list or you can input. It takes a couple more steps,
but does the trick. Using Crystal allows us to store our terms and
conditions which are sent with every purchase order. I would like to see
epicor enable you to click on the printer icon and give you an option to fax
/ print the purchase order or both.
ideas?
Thanks!
Malcolm Spann
MIS
(925) 606-6500 x19
(925) 606-6505 FAX
Malcolm@...
begin 600 winmail.dat
M>)\^(A,-`0:0"``$```````!``$``0>0!@`(````Y`0```````#H``$(@`<`
M&````$E032Y-:6-R;W-O9G0@36%I;"Y.;W1E`#$(`06``P`.````T0<+``$`
M!P`9`#4`!``]`0$@@`,`#@```-$'"P`!``<`&0`U``0`/0$!"8`!`"$````P
M-3DV03$R-D8U0T1$-3$Q0CDY0C`P,3`U03$U,#=$,@#[!@$$@`$`(@```%)%
M.B!;5F%N=&%G95T@1F%X:6YG(&9R;VT@5F%N=&%G90"F"P$-@`0``@````(`
M`@`!`Y`&``0.```S`````P`V```````#``6`""`&``````#`````````1@``
M``!2A0``)VH!`!X`"8`((`8``````,````````!&`````%2%```!````!```
M`#DN,``+`#B`""`&``````#`````````1@`````&A0````````,`"H`((`8`
M`````,````````!&``````&%````````"P``@`@@!@``````P````````$8`
M`````X4````````+`!.`""`&``````#`````````1@`````.A0````````,`
M`H`((`8``````,````````!&`````!"%`````````P`4@`@@!@``````P```
M`````$8`````$84````````#`!:`""`&``````#`````````1@`````8A0``
M`````!X`)8`((`8``````,````````!&`````#:%```!`````0`````````>
M`":`""`&``````#`````````1@`````WA0```0````$`````````'@`G@`@@
M!@``````P````````$8`````.(4```$````!``````````(!"1`!````/0<`
M`#D'``!?#```3%I&=1#7O:D#``H`<F-P9S$R->(R`T-T97@%00$#`??_"H`"
MI`/D!Q,"@`_S`%`$5C\(50>R$24.40,!`@!C:.$*P'-E=#(&``;#$27V,P1&
M$[<P$BP1,PCO"?>V.Q@?#C`U$2(,8&,`4#,+"0%D,S864`NF(%<X92!0!1`"
M,!T03R>)!"!T:`-@=6=H$B`X<GES`9`#(`!P9""B=100($QI'B!T`P"`;F<@
M1F%X+A_B^"!N=0;0!)`$(`K`'0!W'H`%L`F`(`N`'<$=`$_D=707L&]K$B$"
M,`#0705`;`0`!4`%L7D(8""V8P.1"X!P(C`@($D%0/4!D&L'D6$CT`A@"U`=
M``,$8"$397!S+"!BL2(P(&1O!Y$AXG0%$'1C:R`@50"0'\$>5VS=%[!W!"`?
M$!W`;R$T(V#W"'`=P`20;2#A'N$%H![@F&ET:0(@!"!W:`W@/QXP(0,)\`5`
M`_`=T"!ETG8$D'D@)$!R$]$?(=\%L`2!)'$K0`A@;![P(R#O).`I(PG@+(!P
M#>`%L0GP[P&@)8$CHBDQ8R,@)W`C8'TAQ'`=,A*!+U$#H![29^YI+*`CDP.1
M;P4P*P$I(OIF(%$O,40Q!"T+(V(&X%T=T"X*H@J$"H`M-O)/+P40,F`OL`,@
M30>0<V&L9V4V\S8T1@-A.@706P=`%Y%M!@`*L&X#H%O7`,`#$"%0.CE50#E1
M(**49T4?P"X%H&U=-C1/!F`",#DP'/!D;@>09%1A>2903R+P;R"Q((PS,290
M`=`P,2`.(*@Z,S0=$$TV-%0ZD!P@=@!P`9`X($!Y86YH(F`)P"51<SOB/#5U
M3&)J!9`\P5M6/^1=]Q_B'[(#4B!"138Z-C0B(/\%P"SU'[(#@3@1!<`M,241
MOD@'T"6``D`=$`#0:PL1W3X1-1Q!.*0@`"\(4"]`^020+U,CX3T@23`=(S6"
M;P.@*V`K,06P:QZ!,T,H_Q[2)2`!`"K0(^`.L![P-C3^<$!P/2`C$4TA`A`I
MX2'Q_3/!*38K/Y`]4R<4(8$I,?HG,5,G)1$L_"90"&`C4;YF0X8F4"K0&"`B
M\&PLT/\V-"DQ3>5&`1/036$@("(072'$)S7Q$H$)\&10P"C_)Q('D$Q2*N`F
M8"S0*_$JT/\?P2'B-C0=@"DB`'!5Q#/"/R"$*T`=`!/@,H%5X64I]R90(>(8
M(',N,"KP'\$'<'\X$4:#-C0)P#U@(8$&X'C_!Y`F4![2)P,.PDJ14@4'0+T?
M8&X'@`(P("`<\"<A$5\?$%?,'E98H1@@<!?!+_5-H6TV*TXHP"90+?`8(/U?
M47HG(1/@-&109":@!1#_+*%0P"&U,\(`D`$`4C(AXOQ(4$@U5*5>HED1(:$G
M0/\F(%NS'=!*D06A4R0F5"M0]PGP3Y)09'-0PA/A3'8%H/YP+-!G!5BD,1IF
MNC@`!X!_9V)4I2905R%,E6N#4?-FYU3D+?`FL&XG-&(+@"*`PRWP(^(G861J
M'Q!0L7]4)F6$7<1R)C8T9`)387?_/^$I(@>!*S$L4FU%8A0AHO4>5B@'D'`%
MD`<Q4V$GP?YC6"97(7$%:_1LPW&R3EQ;8`0G0'E7PRE`92,@;=<W@0ZP,0@M
M(5`M"K!Y8(9R?U!J\2U&05@A,)QH=0$@)8!5$4%N4W8[9L$M0#].>Q/@<M!S
M(>U$#PI5((06/84?AB^&^F>$%CE;B`=)4X@).V,@GSNQ36$&<1_`A!8H.0XP
MQ"D@'#`V+39($!90V'@Q.8O/C-(U'^"`4/^(#3LNA(^1_Y,/DV.0]S8_$Y8/
M-O`@64!B(2!'OT"S.<$K$06QEC\V\GXV\#H^E01'%"`CD@7`1E)L145#@`9Q
M4U]Q,E!UZV;"+L-C"'%T5V$&\"(P[RL#3:*:XUHP8F:A#K`Y,/L)\`4`>6E%
M71``@"+A*P+_)E"<I%O2:0$`<!0@7;4ELH.#11^`='`Z+R\?$!L[X#"2+D!3
M.^(O56X`3C)W0B]M-5_00T%!+WV@9X!`I2#84&A&!O"DL%0_)9C__Z>OJ+^I
MSYGQFC65!">P`1!_+C!-0DKP39>75)?%0D4@W$)O1[(A`3DP*`>P-?#WGM&7
M0".Q;7.A6E0'0&0!WF0LT*Q2(8&:XV4Z0A[`_F1E@'<26-(CD$!B(:!0$U\O
MI0#0>B`$$"`@*94$*-XQC(`_D+0U(=-&`Q`'D;\&8*`34C(IPJTY39-2>"3^
M0IP@+D`2@1[2'E:XI"I$N57$)V<B8"K0!Y`G)E#_)7$M0KN`.H%&@*+40*6C
MR-U`HR\_U6)PMF(O51&TU?XRM5,4$`K`*X$=U@;PH?'\<V<=H;R?O:^^N'<"
M.!'J<[35,[53=@B0!^"L5'\I,9N`'N`%L!VR9*$Q4&_OQE!FT:X&%!!RQE"T
M8<(__\-/OJFL5)4*K\$%P!\24D%_EUQ*D5N`0<,I(J+%)K!C=\JZ"X`"$"\J
M`S0`E0I]`=+@````'@!P``$````>````6U9A;G1A9V5=($9A>&EN9R!F<F]M
M(%9A;G1A9V4````"`7$``0```!L````!P6(Z_9@FH8$BS?41U;F;`!!:%0?2
M`"<X4/```P`F```````#`"X```````L``@`!`````@$Q``$````H`0``4$-$
M1D5",#D``0`"`'4`````````.*&[$`7E$!JANP@`*RI6P@``14U3341"+D1,
M3```````````&U7Z(*IF$<V;R`"J`"_$6@P```!!3D12251:+4U!24P`+V\]
M3U)',#`Q+V]U/55305),,#$O8VX]4F5C:7!I96YT<R]C;CU286QE>0`N````
M`````#N>M=R0O](1N34`$%H5!](!`!N7`Q*OL-(1N1$`$%H5!](````$[LL`
M```````N`````````#N>M=R0O](1N34`$%H5!](!`!N7`Q*OL-(1N1$`$%H5
M!](````$[LP``!`````%EJ$F]<W5$;F;`!!:%0?2(@```%)%.B!;5F%N=&%G
M95T@1F%X:6YG(&9R;VT@5F%N=&%G90`#``E9`0```!X`0A`!````(@```#PS
M0D1&1#,X."XR,#`X,RXX1#5%,CE`;&]C86QH;W-T/@````,`WC^O;P``0``Y
M`-!#%+O88L$!`P#Q/PD$```>`#%``0````8```!204Q%60````,`&D``````
M'@`P0`$````&````4D%,15D````#`!E```````,`_3_D!````P"`$/____\"
M`4<``0```#4```!C/553.V$](#MP/4]21S`P,3ML/4%.1%))5%HM34%)3"TP
M,3$Q,#$Q,S(U-3-:+3$W,#0V``````(!^3\!````2`````````#<IT#(P$(0
M&K2Y"``K+^&"`0`````````O3SU/4D<P,#$O3U4]55-!4DPP,2]#3CU214-)
M4$E%3E13+T-./5)!3$59`!X`^#\!````#0```%)A;&5Y+"!3=&5V90`````>
M`#A``0````8```!204Q%60````(!^S\!````2`````````#<IT#(P$(0&K2Y
M"``K+^&"`0`````````O3SU/4D<P,#$O3U4]55-!4DPP,2]#3CU214-)4$E%
M3E13+T-./5)!3$59`!X`^C\!````#0```%)A;&5Y+"!3=&5V90`````>`#E`
M`0````8```!204Q%60```$``!S`2!?.ZV&+!`4``"#`PBEF[V&+!`1X`/0`!
M````!0```%)%.B``````'@`=#@$````>````6U9A;G1A9V5=($9A>&EN9R!F
M<F]M(%9A;G1A9V4````>`#40`0```#@````\,4(Y-S`S,3)!1D(P1#(Q,4(Y
M,3$P,#$P-4$Q-3`W1#(P,3,Y-S!#-4!!3D12251:+4U!24P^``L`*0`!````
M"P`C```````#``80W^@RJ0,`!Q!F"````P`0$``````#`!$0`````!X`"!`!
M````90```%=%4%))3E103U-42%)/54=(0U)94U1!3$%.1%5314Q)1TA43DE.
M1T9!6$9!6$Y534)%4E-!4D535$]2141)3E1(14]55$Q/3TM#3TY404-43$E3
M5$]264]50T%.24Y0551)5%0``````@%_``$````X````/#%".3<P,S$R049"
M,$0R,3%".3$Q,#`Q,#5!,34P-T0R,#$S.3<P0S5`04Y$4DE46BU-04E,/@!A
!R`==
end
Just curious - what's winmail.dat & how did it get attached?
>From: Malcolm Spann [mailto:Malcolm@...]
>ideas?
>Thanks!
> Malcolm Spann
> MIS
> (925) 606-6500 x19
> (925) 606-6505 FAX
> Malcolm@...
>have already linked your email address to a yahoo id to enable access. )
I don't know either but it was immediately deleted.
Shirley H. Graver
(End User)
Systems Administrator
Rubber Associates Inc.
Ditto on the delete. Strange that yahoo let the attachment through. Moderators?????
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, November 01, 2001 10:28 AM
Subject: RE: [Vantage] Faxing from Vantage
Shirley H. Graver
(End User)
Yahoo! Groups Sponsor
ADVERTISEMENT
Found it. Looks like Steve has some changes to make his Exchange/Outlook
setup.
Here's what MS has to say:
XFOR: How to Prevent the Winmail.dat File from Being Sent to Internet Users
The information in this article applies to:
· Microsoft Exchange Windows 3.x client, version 4.0
· Microsoft Exchange Windows 95/98 client, version 4.0
· Microsoft Exchange Windows NT client, version 4.0
SUMMARY
This article describes how either an Exchange Server administrator or end
users can prevent the Winmail.dat attachment from being sent to Internet
users when using the Microsoft Exchange Internet Mail Connector (IMC).
When an end user sends mail to the Internet from an Exchange Windows or
Outlook client, a file attachment called Winmail.dat may be automatically
added to the end of the message if the recipient's client cannot receive
messages in Rich Text Format (RTF). The Winmail.dat file contains Exchange
Server RTF information for the message, and may appear to the recipient as
a binary file. It is not useful to non-Exchange Server recipients.
MORE INFORMATION
To control whether or not to send messages in RTF, follow the option that
best meets your situation:
· Creating Custom Recipients
When an administrator creates a custom recipient using the Microsoft
Exchange Administrator program, click to clear the Always Send To This
Recipient In Microsoft Exchange Rich-Text Format check box.
· Modifying Existing Microsoft Exchange and Custom Recipients
An administrator can prevent an existing user account (Microsoft Exchange
user or custom recipient) from sending RTF information by clicking to clear
the MAPI Recipient check box on the Advanced property page of the
recipient's properties. An administrator can view the recipient's
properties by clicking the recipient name, and then clicking Properties on
the File menu.
· Addresses in the Personal Address Book
End users can modify the Internet addresses in a personal address book
(PAB) to prevent sending RTF information by clicking to clear the Always
Send To This Recipient In Microsoft Exchange Rich-Text Format check box in
the SMTP - Address property page of the Internet address in the PAB. To
obtain the properties of an entry in the PAB, click the entry, and then on
the File menu, click Properties.
· Configuring the Internet Mail Connector (IMC)
An administrator can configure the IMC with RTF options in the following
manner:
Open the Internet Mail Connector Properties page.
Click the General tab.
The Send Microsoft Exchange Rich Text list box controls the sending of
rich-text data. There are three values to choose from:
· If the value is set to User, the recipient properties are used to
determine whether or not to send RTF information.
· If the value is set to Always, RTF information is always sent,
regardless of the recipient properties.
· If the value is set to Never, RTF information is never sent.
An administrator can also configure the option to send RTF information on a
domain-by-domain basis. To define e-mail domains and the message settings
for that domain, click the E-Mail Domain button of the Internet Mail tab.
· One-Off Addressing
Anyone can send e-mail to an Internet user from an Exchange or Outlook
client by using one-off addressing. One-off addressing allows you to send a
message to addresses that are not in the PAB, the global address list, or
in any recipient containers.
Depending on the type of the one-off address used, RTF information is or is
not sent with the message:
· Rich-Text Information Is Sent:
If the one-off address has the following format, RTF information is sent
with the message:
[SMTP:SMTP Address]
where SMTP Address is any valid SMTP address, for example:
user@...
To verify that RTF information is sent:
In a new message, type the address in the SMTP address format in the To
field. On the Tools menu, click Check Names. You will see the SMTP address
without the "SMTP:" and the name is underlined.
Double-click the address to bring up its properties.
If the Always send to this recipient in Microsoft Exchange rich-text format
check box is selected, rich-text information (the Winmail.dat file) is sent
along with the message.
· Rich-Text Information Is Not Sent:
If an end user is using a one-off address and does not want to send RTF
information to the recipient, the address should have the following format:
SMTP Address
user@...
NOTE: Unlike the address in the "Rich-Text Information Is Sent" section,
the SMTP address is not proceeded by "SMTP:" and the address is not
enclosed in square brackets ([]).
If the Check Names check box is selected, the properties of the address
will show that the rich-text option is not selected.
However, no matter what option is selected for the address of the
recipient, the IMC settings determine whether or not RTF information is
transmitted. If the IMC is set to never send RTF information, even if the
properties of the recipient address have the rich-text option selected, no
RTF information is transmitted.
If the IMC has separate settings for individual domains, the settings for
those domains takes precedence for all messages addressed to users in those
domains.
Optionally, instead of typing the hex value in the edit field, click
Editor, select File Version, and then click OK. On the File Version tab, in
the fields provided, type the appropriate build number of Imcadmin.dll in
the following format 5.5.2650.24. To determine the correct build number of
Imcadmin.dll, do a search for the file on the Exchange Server. Once you
have found it, right-click it, click Properties, and then click the Version
tab. The build number appropriate to your server is listed here. Type this
number into the value field and click OK. You then see the appropriate Hex
value in the edit field.
Additional query words: rtf internet mail .dat
Keywords : kbusage exc4
Issue type : kbhowto
Technology : kbExchangeSearch kbExchange400 kbExchangeClientSearch
kbZNotKeyword kbZNotKeyword2 kbZNotKeyword3 kbExchange400NT kbExchange400Win95
>Shirley H. Graver
>(End User)
Any moderator know how the ATT00002.txt attachment got delivered with this
message???
Norm
I ran across this problem 6 mo ago with our setup. It's a bug in Outlook.
Certain web-based email recipients may not be able to get your attachment.
Since we have web-based email service rather than a POP3 server on the
premises, we couldn't send attachments to people in our own office, as well
as some others outside the company. It shows up as winmail.dat, and I think
there's another text file that comes with it.
No fix at the time I looked. Only occurs in Rich Text format emails. We
keep our email format set on HTML and get 95% of the "cute factor" of Rich
Text, and can still send attachments to everyone.
Gary Polvinale
Denton ATD
Sent: Thursday, November 01, 2001 10:38 AM
setup.
SUMMARY
MORE INFORMATION
the File menu.
manner:
with the message:
[SMTP:SMTP Address]
user@...
SMTP Address
user@...
domains.
kbExchange400Win95
>Shirley H. Graver
>(End User)
I'm interested to hear the preferred faxing software that works best with
Vantage
Regards,
Dennis O'Hara
Finance Controller
The Signcraft Group
Tel 61 3 9687 8455 Fax 61 3 9687 7235
E-mail d.ohara@...
Dennis,
Everyone here loves Acrobat 4.0. It allows them the option of emailing the
file, saving it, or printing it out. It works with all major programs as
well as Vantage. Acrobat format is universally accepted, and the reader is
free. And if they have the full version on the other end, they can modify
the document and send it back to us with the changes.
I'm not familiar with the functionality of the fax programs, but this is
pretty cool. Not real cheap, but people here think it's worth having. I
give it an 85... it has a good beat, and it's easy to dance to.
Gary Polvinale
Denton ATD
Sent: Thursday, January 17, 2002 3:19 PM
To: 'Vantage User Group'
Vantage
Regards,
Dennis O'Hara
Finance Controller
The Signcraft Group
E-mail d.ohara@...
Winfax Pro 10.0 from Symantec. I can fax or email from Vantage.
Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St. Ext.
Meadville, PA 16335 p.8143336331 x236 f.8143372548 tlw@...
<mailto:tlw@...> www.chipsco.com <http://www.chipsco.com/>
Vantage
Regards,
Dennis O'Hara
Finance Controller
The Signcraft Group
E-mail d.ohara@...
ADVERTISEMENT
<http://rd.yahoo.com/M=219350.1833377.3346791.1269402/D=egroupweb/S=17050071
83:HM/A=935578/R=0/*http://www.gotomypc.com/u/tr/yh/grp/300_1b/g22lp?Target=
mm/g22lp.tmpl>
Boy, are you giving away your age!
Nora Story
Spectra Technologies, Inc.
817-540-4475, ext. 105
Nora_Story@...
I give it an 85... it has a good beat, and it's easy to dance to.
> Gary Polvinale
> Denton ATD
Hey now, American Bandstand is still in reruns! And hmmm, how would you
know this?? But I do dance the jitterbug. What's that do to my
ge?? -Gary
Sent: Thursday, January 17, 2002 3:46 PM
Nora Story
Nora_Story@...
> Gary Polvinale
> Denton ATD
If you already have Exchange and Outlook, then look at FaxMaker. Never had
a glitch.
Sent: Thursday, January 17, 2002 2:19 PM
Vantage
Regards,
We have used Zetafax ( www.Zetafax.com ) for 6 years and it has been
bulletproof. Receives all of our faxes and forwards them as well as
allowing us to fax out from any software including Vantage.
Jerry Boyle
Sipco Molding Technologies
Meadville, Pa. 16335-6725
814.724.2243
www.sipco.com
Vantage 5.00.338
Vantage
Regards,
Dennis O'Hara
Finance Controller
The Signcraft Group
E-mail d.ohara@...
Let's see ... Jamie Brockett - "Remember the wind and the rain" album ?
Sent: Thursday, January 17, 2002 2:46 PM
Nora Story
Nora_Story@...
> Gary Polvinale
> Denton ATD
ADVERTISEMENT
mm/g22lp.tmpl>
<http://us.adserver.yahoo.com/l?M=219350.1833377.3346791.1269402/D=egroupmai
l/S=1705007183:HM/A=935578/rand=513579445>
