Our automatic uplift (via workbench not cloud services) failed conversions 830 and 840, and this causes us not to be able to view AR invoice edit list, nor post AR invloice group.
Error messages from the conversions we attempted to re-run are below. Any feedback appreciated.
…Monty.
*830 conversion attempt:
This is a duplicate entry of an existing record
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:_Releases\ICE\3.1.600.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 535
at Ice.Services.Lib.RunTaskSvcFacade.RunTaskDirect(Int64 ipTaskNum) in c:_Releases\ICE\3.1.600.0\Source\Server\Services\Lib\RunTask\RunTaskSvcFacade.cs:line 103
at Ice.Core.TaskServiceBase1.InnerRunDirect(IceRow paramRow) in C:\_Releases\ICE\3.1.600.16\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskServiceBase.cs:line 584 at Ice.Services.Proc.CnvProgsProcessSvc.RunDirect(CnvProgsProcessTableset ds) in c:\_Releases\ICE\3.1.600.0\Source\Server\Services\Proc\CnvProgsProcess\CnvProgsProcess.Designer.cs:line 189 at Ice.Services.Proc.CnvProgsProcessSvc.RunConversion(String systemCode, String converionID) in c:\_Releases\ICE\3.1.600.0\Source\Server\Services\Proc\CnvProgsProcess\CnvProgsProcess.cs:line 48 at Ice.Services.Proc.CnvProgsProcessSvcFacade.RunConversion(String systemCode, String converionID) in c:\_Releases\ICE\3.1.600.0\Source\Server\Services\Proc\CnvProgsProcess\CnvProgsProcessSvcFacade.cs:line 55 at SyncInvokeRunConversion(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func
2 func) in C:_Releases\ICE\3.1.600.16\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:\_Releases\ICE\3.1.600.16\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28 at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\3.1.600.16\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23 at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result) at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result) at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SecurityChannelListener
1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
*840 conversion attempt
Corresponding UD fields (‘VNACGroup’, ‘VNACType’) for table ‘GLJrnDtl’ should be added before
Corresponding UD fields (‘VNACGroup’, ‘VNACType’) for table ‘GLJrnDtlMnl’ should be added before
Corresponding UD fields (‘VNACGroup’, ‘VNACType’) for table ‘RvJrnTrDtl’ should be added before
Best,
…Monty.
Monty Wilson ERP Developer
ERP Developer
Black Horse LLC
Houston TX
832-399-4643
