Hi, the EDD installer is giving us an error when we are trying to upgrade EDD from 10.2.500.16 to 10.2.500.18. Is there a way to run the install but ignore the backup portion?
Thank you,
Validating Deployment Data.
Installer has detected SSL/TLS vulnerability, Please review install logs for details.
Deployment of Data Discovery started.
Installation of Epicor Data Discovery Started.
ERROR: Failed to deploy Epicor Data Discovery : Failed to back up file contents : Could not find a part of the path ‘F:\Epicor\Websites\Data Discovery2’.
Deployment of Data Discovery Failed.
Errors:
I was not able to find a way around it. I was going to 10.2.600.4 and someone told me it was a bug that was fixed in 10.2.600.5. Haven’t tried it yet. Sorry I am not more help. Epicor tech support is still working on it.
The installer tries to backup the SQL database to the EDD path on the app server. In Michel’s case F:\Epicor\Websites\Data Discovery2
That’s not a valid directory on the SQL server. A work around is to create that directory on the SQL server then the backup will be successful and EDD will finish.
