External Company Account Segment Value Set Up
Hi All
Anyone using Multi company set up in Epicor E10?
May i know where can we set up the External GL Account as indicated in the screenshot?
I’m looking in 10.2.700, but it should be the same.
There are two places… first you need to create your GL Control Code for Multi-Company that contains the map for each of your control types.
Then, under System Setup > External System Integration > Setup > External Company Configuration. Under the GL Control tab you assign the GL Control Code.
Thanks Ernie.
I do have the multi company GL control set up. But i am not sure why the profit centre list is not complete. I have trigger a resync of the GL codes and it is working now.
Still don’t understand why some of the profit centre is missing from the list out of sudden.
