I had a similar problem with part descriptions, due to some extremely long descriptions that had been cut & paste into Epicor. The fix for me was: select CAST(PartDescription AS VARCHAR(1024)) AS [PartDescription] ...
Epicor 9.05.607B, SQL Server 2008.
Brian.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tanya Denison
Sent: Thursday, November 29, 2012 5:34 PM
Subject: [Vantage] External BAQ - empty fields
We are on 9.05.605, SQL Server 2008
I have an external BAQ that I have created, but not all of the data comes across when I run it. I have pared it down to a very simple example.
Create view Test as (select * from part)
When I bring this view into the BAQ Designer, and show all columns, the PartDescription and Character01 (our legacy part ID) fields are empty. I have tried replace() in SQL Server to eliminate any special characters, but it still won't show any text. The view displays correct in SQL Server Management Studio.
I found the unique characters in the first position in the string:
Select distinct substring(partdescription,1,1) from part
Then I did a replace to eliminate any special characters:
Select
replace(replace(replace(replace(SUBSTRING(part.PartDescription,1,1),'.','Q'),'*','Q'),'"','Q'),'
','Q') as [testone] from part
Then selecting from Management Studio gave me a lot of single characters, but displaying in BAQ Designer shows all rows with no value.
Does anyone have any experience with this kind of issue with External Queries?
*Tanya Denison* | IT Manager | NRS, Inc.
*2009 S. Main Street, Moscow, ID 83843*
*tdenison@... *|* www.nrsweb.com*
*c: 208.301.0599* | *p: 208.883.7834 Ext 277 *|* f: 208.882.1744*
Brian.
Select
