I have a BAQ that i want to access an external database on. I created an External BAQ. Is there a way to also get the kinetic database in this BAQ?
If not, any ideas of how i can see the data from the external database in kinetic? View, sproc?
You can connect your external source to the kinetic db and get both in a single view. Though this bypasses all of Epicor’s security it is generally not recommended.
What would you recommend doing? I know someone has had to have crossed this bridge before.
What is the problem you are trying to solve? There are a few ways to tackle this
The is an existing BAQ that have four queries contained in the dashboard. For one of the BAQ queries in the dashboard they want to pull in external data that will give them dimensions of a part.
In a dashboard you can use Publish subscribe to tied everything together you should be fine
