ExtendedProperties problem
Hello all,
I have set the extended properties of QuoteDtl.CheckBox05 and CheckBox06 to ReadOnly on form load. I have code written that when CheckBox04 is checked, it is supposed to set CheckBox05 and CheckBox ReadOnly to false but it is not working…
Here’s a part of my code. The checking of CheckBox06 works just fine…
edvQuoteDtl.dataView.Table.Columns["CheckBox05"].ExtendedProperties["ReadOnly"] = false;
edvQuoteDtl.dataView.Table.Columns["CheckBox06"].ExtendedProperties["ReadOnly"] = false;
args.Row["CheckBox05"] = false;
args.Row["CheckBox06"] = true;
Chris
I would recommend row rules for this instead.
Jason,
I don’t see where I can do this as a row rule especially being toggled by a checkbox?
In your Customization Dialog use the Rule Wizard. Once you setup the rules they will be re-evaluated as Notifications are sent when values change. In the Application help you can find more info on how to use it. But if you are a developer, its pretty straight forward.
Rich sums it ups pretty good:
In the Epicor Client, the data controls the UI elements and the Epi-Controls respond to the Extended Properties “metadata” defining both a column and a cell. You do not color a control, you color the data; You do not disable a control, you disable the data. We do this so that any control displaying the data - individual field, Grid, or control added via Customization - will display and managed the data in the same way.
Use Row Rules and the UI will behave as you expect.
– Rich from Epicor
