On Wed, Nov 9, 2011 at 4:03 PM, jgiese1988
<jgiese@...>wrote:
> Is there any ways to transfer extended UD fields from one database to
> another so I don't have to recreate them from scratch.
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
--- In vantage@yahoogroups.com, Waffqle <waffqle@...> wrote:
> If you're looking for a simple click-click way, the answer is sadly 'no'.
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
Hi, I have tried to create an extended UD table for JobHead (Epicor 9.05.701).
I have added one decimal field (called RDFlow2hrs), then ran the Update UD Schema.
I then restarted the App Servers, but when I go into Customisation mode, I cannot see this new field there.
Am I missing something?
Thanks a lot for your help!
hi -
What you did should have worked.
Can you see them in a simple BAQ?
Can you go into the Epicor DB (in SQL Management Console) and see a table called JobHead_UD table ?
Have you checked the serverlog to make sure you did not get any errors?
I have done this a couple of times, and it has worked. So we just need to figure out the step you might have missed.
Marianne Gizzi
I cannot see them in a simple BAQ. If I go into the Epicor DB (in SQL Management Console) I cannot see the JobHead_UD table either.
I created a UD field to extend MemoCat (which does not have any ud fields…), but I can’t get it do anything. I need to use the field in a data directive as well as modify the memo category setup form to display this new field.
Tom Christie | Information Technology Manager | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
Sent: Thursday, June 19, 2014 4:28 PM
Subject: [Vantage] Re: Extended UD Tables
Hi thanks for your help
There aren't any entries on the server log either...
I have logged a support call with Epicor, not sure what is going on here
Does anyone have any instructions on how to get the extended ud tables to work in 9.05. I created it through Epicor’s form, but it does not appear throughout the system.
Tom Christie | Information Technology Manager | AGM Container Controls, Inc. | tchristie@... | t: 520.881.2130 ext 2176
Sent: Wednesday, July 9, 2014 4:48 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: Extended UD Tables
Did you have any resolution on this?
From: "'Tom J. Christie' tchristie@... [vantage]" <vantage@yahoogroups.com>
To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
Sent: Thursday, July 10, 2014 10:59 AM
#ygrps-yiv-454769217yiv4337357121 .ygrps-yiv-454769217yiv4337357121ygrp-photo-title{
clear:both;font-size:smaller;height:15px;overflow:hidden;text-align:center;width:75px;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121ygrp-photo{
background-position:center;background-repeat:no-repeat;background-color:white;border:1px solid black;height:62px;width:62px;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121photo-title
a,
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121photo-title a:active,
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121photo-title a:hover,
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121photo-title a:visited {
text-decoration:none;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121attach-table div.ygrps-yiv-454769217yiv4337357121attach-row {
clear:both;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121attach-table div.ygrps-yiv-454769217yiv4337357121attach-row div {
float:left;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p {
clear:both;padding:15px 0 3px 0;overflow:hidden;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121ygrp-file {
width:30px;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121attach-table div.ygrps-yiv-454769217yiv4337357121attach-row div div a {
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121attach-table div.ygrps-yiv-454769217yiv4337357121attach-row div div span {
font-weight:normal;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 #ygrps-yiv-454769217yiv4337357121 –
filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
#ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121MsoNormal, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121MsoNormal, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121MsoNormal
{margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 a:link, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 span.ygrps-yiv-454769217yiv4337357121MsoHyperlink
{color:blue;text-decoration:underline;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 a:visited, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 span.ygrps-yiv-454769217yiv4337357121MsoHyperlinkFollowed
{color:purple;text-decoration:underline;}
{margin-right:0in;margin-left:0in;font-size:12.0pt;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 code
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 pre
{margin:0in;margin-bottom:.0001pt;font-size:10.0pt;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 tt
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 span.ygrps-yiv-454769217yiv4337357121HTMLPreformattedChar
{font-family:Consolas;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121attach, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121attach, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121attach
{margin-right:0in;margin-left:0in;font-size:9.0pt;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121bold, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121bold, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121bold
{margin-right:0in;margin-left:0in;font-size:10.0pt;font-weight:bold;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121green, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121green, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121green
{margin-right:0in;margin-left:0in;font-size:12.0pt;color:#628C2A;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121replbq, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121replbq, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121replbq
{margin:3.0pt;font-size:12.0pt;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121ad, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121ad, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121ad
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121underline, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121underline, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121underline
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 span.ygrps-yiv-454769217yiv4337357121yshortcuts
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121ad1, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121ad1, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121ad1
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121ad2, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121ad2, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121ad2
{margin-right:0in;margin-bottom:7.5pt;margin-left:0in;font-size:12.0pt;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 p.ygrps-yiv-454769217yiv4337357121underline1, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 li.ygrps-yiv-454769217yiv4337357121underline1, #ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121underline1
{margin-right:0in;margin-left:0in;font-size:12.0pt;text-decoration:underline;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 span.ygrps-yiv-454769217yiv4337357121yshortcuts1
{font-weight:bold;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 span.ygrps-yiv-454769217yiv4337357121yshortcuts2
{font-weight:normal;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 span.ygrps-yiv-454769217yiv4337357121EmailStyle34
{color:#1F497D;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 .ygrps-yiv-454769217yiv4337357121MsoChpDefault
{font-size:10.0pt;}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 div.ygrps-yiv-454769217yiv4337357121WordSection1
filtered #ygrps-yiv-454769217yiv4337357121 {}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Symbol;}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {}
#ygrps-yiv-454769217 filtered #ygrps-yiv-454769217yiv4337357121 {font-family:Wingdings;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 ol
{margin-bottom:0in;}
#ygrps-yiv-454769217 #ygrps-yiv-454769217yiv4337357121 ul
